Go Back   MBWorld.org Forums > Mercedes-Benz SLR & SL Roadsters > SL/SLC-Class (R107)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-03-2010, 10:47 AM   #1
Drives: 1978 450SL
Help! Hardtop removal
I originally posted this in the wrong place, oops!
I bought my first Benz ~1978 450SL~ and I have no idea how to remove the top. I see the tool, I see where the locking mechanisms are, and I can give each lock 1/2 turn. I see the tension release and the top rise slightly, then ?????
To remove this ad, register today or login if you already are registered!
__________________
1978 450SL ~ mine
FFR MKII registered 65 Shelby Cobra ~ his
others less interesting...
96 Lexus...01 Ford F150...07 Sentra...08 Yaris, thrown in for good measure to balance our carbon foot print
bettybenz is offline   Reply With Quote
Old 05-04-2010, 08:54 AM   #2
slik560's Avatar
Drives: 1987 560SL 2003 ML320
you have to release the rear of the top with the lever on the side behind the driver's seat. Push it towards the rear of the car and this should release the pinion on the hard top that inserts into the body. The levers are used for the two side latches and the two on the windshield latches. That top weighs about 90 lbs, so removal is NOT a one person job...unless you have one of those special hardtop winches installed in your garage. There was a separate hardtop manual that came with the car, if you're lucky enough to have had the original owner keep everything. It might be something to order from MB.
__________________
Kevin A
1987 560SL
2003 ML320
slik560 is offline   Reply With Quote
Old 05-04-2010, 09:28 AM   #3
Drives: 1978 450SL
It's the turn-handle part that I was missing. Skies are blue this morning after a spring thunderstorm late yesterday afternoon, so NOW I can take her out topless. Thanks so much!
__________________
1978 450SL ~ mine
Old 05-05-2010, 12:00 PM   #4
slik560's Avatar
You're welcome. Once I got my hartop off, it's been sitting on a wheeled carrier in the garage with a cover on it. I may never have it on again unless I'm forced to drive the car during the winter months.
__________________
Kevin A
1987 560SL
2003 ML320
Old 05-12-2010, 10:46 PM   #5
Drives: 1980 450SL
Hard Top Removal
Hello,
Kudos on getting your top off. I thought I'd post this pdf file for others.
Breezie
Breezie is offline   Reply With Quote
Old 06-25-2010, 06:24 PM   #6
Drives: E500, 450SL
450SL hard top garage winch
Where can I purchase a garage winch to remove and install my hard top? Is there a specific product sold, or are there other, better winches that work well.
Ari Bass is offline   Reply With Quote
Old 06-28-2010, 02:05 PM   #7
Drives: 1984 500SL AMG
I use a Harbor Freight electric hoist and the top straps sold by Performance Products. Less than $150.00 total if you catch the hoist on sale. Top weighs 90 pounds.
myway is offline   Reply With Quote
Old 07-07-2010, 03:14 PM   #8
Drives: E500, 450SL
Thanks. I appreciate the guidance.
Old 06-05-2011, 11:38 AM   #9
Richard / E320's Avatar
Drives: 2001 E320
Here's a post with instructions for removing and installing both the hardtop and soft top from another forum.
http://www.benzworld.org/forums/r-c1...-soft-top.html
__________________
Richard / E320
2001 M-B E320 / Glacier White w/ Java Leather / 18" AMG Style III & Bridgestone Potenza's / H&R Springs
Richard / E320 is offline   Reply With Quote
Tags
1987, 1989, 380, 450sl, 560, 560sl, ads, hard, hardtop, mechanism, print, releasing, removal, sl, top
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
