Go Back   MBWorld.org Forums > Mercedes-Benz SLR & SL Roadsters > SL/SLC-Class (R107)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-06-2011, 04:57 PM   #1
Drives: R107
380sl Air/Fuel Ratio VERY RICH after warmup
Hi everyone.
We took a 1000 mile trip and along the way the car started running extremely rich, pouring black smoke. It runs perfectly until it's warmed up completely, or if is running over 80 mph it runs fine all the time.
It has 146k and had a complete tuneup, including all ignition, fuel pump, fuel filter, timing chain, guides, plus more, less than 10k ago.
Any ideas? We need to drive this back those 1000 miles. I have access to tools. All help is greatly appreciated. Thanks.
To remove this ad, register today or login if you already are registered!
Build is offline   Reply With Quote
Old 08-14-2011, 06:11 PM   #2
There is a hole on the top of the air cleaner. Performance Products sells a tool that looks like a long allen key that goes into this hole. You can adjust the air/fuel mixture while the car if running by inserting this tool and slowly turning it.
__________________
Joe
jnappi is offline   Reply With Quote
Old 12-14-2011, 07:47 AM   #3
Drives: 1981 380 sl
CHECK ALL OF YOUR VACUUM LINES I HAD THE SAME PROBLEM ITS A VACUUM LEAK
RALPH221 is offline   Reply With Quote
Tags
380, 380sl, adjusting, air, benz, black, chain, fuel, mercedes, ratio, rich, running, sl, smoke, start, timing
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
