Go Back   MBWorld.org Forums > Mercedes-Benz SLR & SL Roadsters > SL/SLC-Class (R107)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-11-2012, 03:27 PM   #1
Hardtop Adjustment
I haven't worked on my 85 380 Sl for a year, so now I am ready to start again. Last year I adjusted the linkage under the cover where the soft top is stored to maek the pinion easier to grab the soft top while putting it up. When I attempted to install the hardtop for the Winter, I couldn't get the pinion to grab and pull the back of the hardtop down. I left it since then. But I am ready to take the hard top off and wanted to know if there are any specs to adjust the linkage properly.
Is this a hit and miss adjustment? Does anyone have experience with this problem? Everything lookd like it is operating ok, but something is just missing this pin from engaging the rear of the hardtop. Any help or advice is much appreciated.
Thanks!!
To remove this ad, register today or login if you already are registered!
__________________
Joe
jnappi is offline   Reply With Quote
Old 04-11-2012, 10:12 PM   #2
Drives: 82 380SL 96 SL500
Wow, here it is cruising season and you're want to work on her...?
Just kidding. As a wild *** guess, is the HT pin oriented correctly? Compare it to the soft top.
Beyond that, though I haven't looked, you might check the online 107 service manual for the correct way or adjusting the latch.
http://www.startekinfo.com/StarTek/o...tedDocId=11883
__________________
Alan
_______________________________________
Some times you just need a bigger hammer
abiby is offline   Reply With Quote
Tags
107, 380sl, adjusted, adjustment, adjustments, hard, hardtop, latch, mercedes, r107, r129, sl55, soft, top
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
