SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: no power after richiner goes off
Old 07-02-2014, 03:57 AM
pinzgauer1's Avatar
mercedes pinzgauer
Hello all and thanks in advance I have an 81 380 sl it sat for a few years so I drained the gas and did a tune up now when the car is cold it runs great but as soon as it warms up it wont hardly move every now and then you here a plunger sound and it comes to life for a few then goes back to no power the vacuum throttle plate seems to be smooth but when it is acting up if I manually push it down some it revs right up like it should otherwise even at in neutral it revs real slow when its warm it I took it to a shop they said probably fuel distributer but they really did drive it much that doesn't make sense to me
Old 07-31-2014, 09:53 AM
slik560's Avatar
SOLD both: 1987 560SL 2003 ML320
Bad cold start valve??? [if you have not done so already, try the 107 forum over at benzworld . org ]
Quick Reply: SL/R107: no power after richiner goes off
