SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Best 12v Source under the hood
Old 08-26-2015, 04:00 PM
caperss's Avatar
2010 S550 4Matic, 88 560SL, 2002 Boxster, 2005 Jaguar Super V8
Hi all, I just received my OBDI tester and I want to check for faults. I need to source +12VDC for the tester since the 8pin socket doesn't have a positive voltage source like the 16 and 32 pin sockets. What is a good source under the hood for 12VDC with the ignition on?
Old 08-27-2015, 07:01 AM
myway's Avatar
450SL
Year and model.
Old 08-27-2015, 09:27 AM
caperss's Avatar
88 560SL
Old 08-27-2015, 09:40 AM
myway's Avatar
450SL
There is a junction block on the right inner fender. It has a cover over it. Open the cover and you will see the positive cable connection. Right is passenger side.
Old 08-30-2015, 02:49 PM
caperss's Avatar
Thanks again MYWAY! It was right where you said and I was able to pull my code with ease.
Quick Reply: SL/R107: Best 12v Source under the hood
