SL/R107: Aux fans run anytime ign. is on.
My aux fans run any time the ignition is on. This started after replacing AC
dryer and the green pressure switch ( w/ aftermarket) as soon as the switch is unplugged fans stop. My question is: could this be the wrong switch? Does anyone have a good MB # for the original The # I have (002-820-52-10) is a dead end..
Thanks...
Thanks...
I'm not familiar with your model car, but many of these fan switches are designed so that their "default" failure mode turns the fan on all the time. This way, if the switch fails, at least the engine won't overheat and suffer damage.
It could also be the wrong switch.
