SL/R107: Fuel system rebuild
Fuel system rebuild
The car has been sitting for years. Varnish is a factor. Fuel tank is out. What parts do you think I need to replace and what parts can be cleaned/flushed and reused.
Fuel filter will be replaced. Hoses will be replaced.
What about the:
Fuel accumulator?
Fuel pressure dampner?
Fuel tank strainer?
Fuel pump check valve?
Thanks for your input?
What about the:
Fuel accumulator?
Fuel tank strainer?
If you have a 107.045, I'd use EPC(or go to a dealer with the VIN) to confirm understanding, but would also look at the fuel cooler, charcoal filter and gauge sending unit!!
