SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Fuel Pump control relay
Old 05-18-2016, 08:58 PM
Steve J's Avatar
1989 560SL
Gentlemen,
I have had conflicting advice on the Location of the Fuel Pump Control Relay
Associated with my 107 1989 560SL. Would someone give me the right advice.
I would like to change this relay before suspecting other components that causes a period engine failure.
Regards
Old 05-19-2016, 01:53 AM
Mark380SL's Avatar
1983 380SL
I'll take a stab at it just because I post things on here and get a ton or reads but no replys.
I believe it is the same as the 380 and is behind the glove box on the firewall. I've been told you have to take the glove box liner out to get to it. I need to do the same but have not had the time to find it yet. Good luck.
Old 05-19-2016, 08:15 AM
myway's Avatar
450SL
Here: http://www.benzworld.org/forums/r-c1...ml#post3616901
Quick Reply: SL/R107: Fuel Pump control relay
