SL55/63/65/R230 AMG: V12 Engine Out (feast your eyes)
Old 02-16-2010, 05:00 PM
  #101
Thericker's Avatar
V12-Biturbo
Originally Posted by Dsmed
"I'm hard I own these streets you brown bastad"
Old 02-16-2010, 09:17 PM
  #102
soulsearcher's Avatar
SL600 (1000 hp), Cayenne S, 996TT EVO GT750, F430 Spyder,A real Ford GT, 08 Gallardo Spyder
x
Originally Posted by DCMETRO22Z
12 pistons... You got more pistons on one caliper than 99% of the cars on their four brakes ... So good.
Originally Posted by Thericker
This blatant Graphic **** has to stop!!!
Originally Posted by Benz-O-Rama
I've made an executive decision to not view this thread anymore, out of sheer jealousy.
Funny stuff...you guys crack me up ( LMAO )
My wife is looking at me right now with a very confused look...
Old 02-16-2010, 09:47 PM
  #103
MORE PICS
Old 02-16-2010, 11:19 PM
  #104
V12Godspeed's Avatar
Your worst nightmare...
Are those your old SL turbos? The stock ones?? somehow they look a lil bigger than the 600's
Old 02-16-2010, 11:21 PM
  #105
Gondon's Avatar
02 S500 Sport
Old 02-17-2010, 11:29 AM
  #106
Sunir's Avatar
SL55 AMG
number of pistons do not indicate stopping efficiency per se. Other factors such as caliper design, caliper bridge strength, rotor efficiency, piston size and clamping force are all factors that play a major role in brake system function. The number of pistons help mostly to increase pad surface area contacted to rotor and uniformity of the distributed clamping force. So for example an Alcon B-series caliper could possibly brake as well as a Stoptech ST-40 caliper or a similar Brembo 6, 8, or Rotora 12 piston caliper depending on the setup of the system, weight of the car, and related factors.
but yes they do look cool as heck!!!
Old 02-17-2010, 12:50 PM
  #107
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Great answer.
Old 02-17-2010, 01:46 PM
  #108
DCMETRO22Z's Avatar
E320
Those are Stock Borg-wagner K24 mounted on 600's & 65's (65's have slightly bigger kompressor and turbine wheels)
Old 02-17-2010, 10:05 PM
  #109
I know that part...., somehow the outer casting looks a little bigger on this one than stock. Thx
Old 02-18-2010, 05:49 AM
  #110
DCMETRO22Z's Avatar
E320
They look stock to me... Bigger would mean brabus, and I don't think Soulsearcher had it.
Old 02-18-2010, 05:52 AM
  #111
DCMETRO22Z's Avatar
E320
Originally Posted by soulsearcher
That New manifold design will act like a header on an Atmo Engine. With the bigger turbo, I think You should have monstrous HP gain if everything is tuned properly.The Stock exhaust/turbo setup on MB V12TT engines is **** poor, like the cooling and intake. And although that, some people could achieve huge HP.
You car should produce 1000RWHP... I'm pretty sure.
Old 02-21-2010, 12:10 AM
  #112
67supersnake's Avatar
2008 SL600 w/AMG pkg
I might just be at the Texas Mile if he can get his car finished. March 26th-28th, correct?
Only 103 miles for me.. a nice cruise in my stock SL600.
Old 02-21-2010, 02:15 AM
  #113
blackbenzz's Avatar
haters crazy
I'm glad someone finally took on a project like this. Ever since I frist saw the v12 biturbo manifold/turbo I knew the key to unleashing the power would be bigger turbos on a custom manifold. Are you going to try and tune through factory ECU? What size turbos are you going to go with? Good luck! Yea the V12 biturbo injectors are pretty small. You can try running 55k injectors, should drop in and provide roughly double the flow. If you wanna go baller you can get SLR injectors
Old 02-21-2010, 04:14 PM
  #114
DoctorV8's Avatar
2005 CL65
Great seeing the pics of the manifolds and turbos. I'd like to see the AMG 6.0 parts side by side! Anyone know if the manifolds look different than these 5.5L parts?
Anyway....I'll be at the Mile in my FGT...come by and say hi!
Regards,
Sanjay
Old 02-21-2010, 04:54 PM
  #115
DCMETRO22Z's Avatar
E320
Regards,
Sanjay
600 and 65 turbos have the same exterior look.The only differences are in the turbos internals.
Old 02-21-2010, 04:56 PM
  #116
DoctorV8's Avatar
2005 CL65
What about the manifolds?
Old 02-21-2010, 05:02 PM
  #117
DCMETRO22Z's Avatar
E320
As I explained many times, In the MB V12TT engines, the turbo setup is very particular.
The exhaust gas manifold and the Turbine wheel housing are casted as one single piece.
So, the Manifold/housing block is the same on the 600 & 65.
That's why you can't simply swap turbos on those engines. You have to cast a band new exhaust manifiold to make your aftermarket turbo fit.
Old 02-21-2010, 11:16 PM
  #118
x
I am assuming that if u are coming, your plans are to spectate only since race registration has been closed for some time. Come by & say hi. We'll be with a bright red 27ft enclosed trailer. I think Marko is also a registered racer.
SLR/55k injector flow specs are not published...you may or may not be correct but based on some formulas, u are probably correct.... Yes we are using the oem ecu, there is no need to install a stand-alone or even a piggy-back race fuel management system, additionally, for obvious reasons you really can not go that route on these cars.
The housing and the turbine wheels size are the same but I believe the compressor wheels are k20/24s on the 65
Regards,
Sanjay
Sounds good. Its easier for you to find us since we'll be the only R230 and as you know, they'll be at least 13 FGTs. Is yours the white 05?
Old 02-21-2010, 11:28 PM
  #119
DoctorV8's Avatar
2005 CL65
Mine is the Quicksilver no stripe with black wheels.
Old 02-22-2010, 12:12 AM
  #120
blackbenzz's Avatar
haters crazy
You don't have to take my advice but I've had both the 55k and SLR injectors flow tested (I posted the numbers somewhere). I'm aware that the SLR specs are not published and I actually have a set on my car. Cool, who is going to be doing the tuning?
Old 02-24-2010, 02:19 PM
  #121
Fronts with 12 piston/16in. (only 1/4in clearance with 20s)
Old 02-24-2010, 02:25 PM
  #122
Benz-O-Rama's Avatar
Those bad boys ought to be able to rearrange your organs when you stomp on em. Wear a kidney belt.
Old 02-24-2010, 02:34 PM
  #123
DCMETRO22Z's Avatar
E320
You're damn right... 12 cylinders, 12 pistons ...
Old 02-24-2010, 05:38 PM
  #124
OUTCAST's Avatar
SLK55AMG, SL600
Wow!
Old 02-24-2010, 07:41 PM
  #125
By the way, the color is red but in the pic it looks orange.
Quick Reply: SL55/63/65/R230 AMG: V12 Engine Out (feast your eyes)
