Sign in using an external account
| SL55 AMG, SL63 AMG, SL65 AMG (R230) Discuss the SL55, SL63 and SL65 AMG. Sponsored by Global Autosports
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2013 CLS550 4Matic
Ugh.....looks like ABC pump just took a dump on me.
__________________
C218 CLS550, E64 BMW M6 Convertible, F02 BMW 750li, R230 SL500, R230 SL55 AMG |
#2 |
Drives: 07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
I would say you're fine to drive it top your shop but who knows.
I would start by putting it on a lift and verify where the leak is originating from, then follow by doing a proper flush and see what the STAR system pulls up for errors and go from there. Good luck. Aaron |
#3 | |
Drives: 2009 SL65, 1998 CL600 (sold), 1989 560SEL (sold)
Quote:
#4 | |
Quote:
have the car read. the abc diagnostic capabilities in das are excellent. there is even an abc stress test routine (not rodeo) that will pinpoint if your tandem pump is on its way out. have the car towed. if your pump is bad it is possible for the car to go all the way down and fluid will overflow from the abc reservoir making the possibility of an engine fire very real. this happened to me on my sl65 and it was a mess. Last edited by alx; 04-09-2012 at 11:50 AM. |
#5 |
#6 | |
Quote:
on a second thought if the system ran dry it will absolutely kill the tandem pump and this is what most likely happened... either way the car would need to be read to identify bad components in the abc (aside from the visual leak test) |
#7 |
I did end up driving to the mechanic.....the car was not slammed so I would imagine there was enough fluid in there to make the 5 mile drive and it got there OK.
If I had any hope of pump still being good....I would have had it towed....but I have pretty much no hope of that.
__________________
#8 |
Yep, just got the call....it's the pump. He also sent the serpentine belt got soaked in the fluid and needs to be replaced.
Does the SL55 and SL500 use the same serpentine belt? I am going to go with a remanufactured pump since I may not keep the car much longer (and it's $650 versus $1500 for OEM pump). I'm just trying to price out the serpentine belt itself.
__________________
| Tags |
| 04, 2004, 500sl, abc, benz, convertible, fir, intermittent, leaking, mercedes, parts, pump, repair, replace, sl500, sl55, warning |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
