Sign in using an external account
| SL55 AMG, SL63 AMG, SL65 AMG (R230) Discuss the SL55, SL63 and SL65 AMG. Sponsored by Global Autosports
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Drives: -
#2 |
Drives: -
#3 |
Drives: Garage Temporarily Empty
There are def secondary cats on an S600. I know because I had them removed....
-Chris
__________________
BROADWAY PERFORMANCE TUNED / EUROCHARGED STAGE 1 / BMC FILTERS / DUAL RESONATOR DELETE / DMH ELECTRIC CUTOUTS / JOHNSON CM30 CHARGE PUMP / AKEBONO BRAKE PADS / STAR LOWERED MBWorld Gun Owner's Club Member #104 |
#4 |
Drives: -
Strange.. any other SL owners know?
#5 |
Drives: 07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
My 07 only has the two main cats.
Aaron |
#6 |
Drives: Eurocharged Stage (1) 2004 E500, OE Tuning/Speedriven ECU/TCU 2005 SL600, 2010 Caddy SwaggerWagon
Only 1 set of cats on V12 SL
__________________
2010 CTS SportWagon 2004 E500 - Eurocharged ECU, VRP headers and E55 exhaust (13.49@102.5) 2005 SL600 - OE Tuning ECU/ Speedriven TCU - (11.02@126.01) ..And some bad **** teefusus. ![]() http://www.youtube.com/watch?v=jb1g_f_gBA0 Outfitted by:
#7 |
Drives: SL 65 AMG, Porsche 911 (993), 2011 Prius 5, 2013 Toyota Highlander Limited
Cats SL 65
One set of cats on a SL 65...
__________________
2005 Brilliant Silver/black-charcoal SL 65 AMG 1995 Grand Prix White/cashmere/blue top Porsche 911 Cab - 993 2011 Blizzard White/Sand Beige Prius 5 2013 Toyota Highlander Limited 4WD
#8 |
Drives: 2007 E63, 2006 C55
R230 V12 Cats
+1. Only 1 set of cats on V12 SL.
Stock exhaust is pretty stout out of the box, huge piping stepped down progressively in diameter from front to rear. Just remove the rear mufflers if you want better sound and maybe a smidgen better flow.
__________________
2007 E63 Silver/Ash, P2, Pano, Parktronic, trunk closer, loaded2006 C55, Black/Black, Premium and Lighting Packages, Navi 2011 Corvette Grand Sport Convertible, Silver/Gray/Blue, every option 2005 SL600 Capri Blue/Ash, AMG Package, Distronic, Keyless Go, Pano, Parktronic, TPMS - Sold |
#9 | |
Drives: SL600 / SL450 (107) / E350 / BMW M5 E60 / BMW 745i (E23) / Toyota Hilux 4 WD/ Honda CBX 1000 (6 cyl)
Quote:
It's seems that somebody have two cats like this setup at this drawing. I have a friend in Germany who have this setup at his SL600.... and he have imported it from USA. So maybe this is why Mercedes give two different hp numbers at the same engine.... 500 hp and 517 hp? 500 hp have two cats.... (first and secondary with resomnators) and 517 have only first cats setup with H-pipe. Here is few pictures from my exhaust systeem and I think it's OEM. Last edited by Ekselent; 04-16-2012 at 01:46 PM. |
#10 |
Drives: V12-Biturbo
US R230 SL600/65 models have what appears to be (1) giant pair of cats, but if you remove them & look inside them you will see where the 2nd set of cats went lol... The giant pair is actually a set of (2) side by side ie (4) total, they welded both pairs together equaling what apears to be only (1) pair from outside but indeed there are (4) cats inside that mini-beer keg exterior.
Remove them ALL for an easy 30+ rwhp Last edited by Thericker; 04-16-2012 at 06:17 PM. |
#11 |
Sorry, I kind of misread......thinking you were referring to an S, not SL.
__________________
#12 | |
Drives: MB Master Tech. 04 S600, 91 240SX 1JZ swap (FOR SALE), 00 ML55, 98 C43-55 Swap With Blower!
Quote:
__________________
Only W220 on 20x12's!
#13 | |
Quote:
"Mini - beer keg"... where is it at the car? Do you mean at the same keg where the first cats are? Welded together? Juha |
#14 | |
Drives: V12-Biturbo
Quote:
#15 |
Drives: V12-Biturbo
#16 | |
Quote:
Thank you.... My friend in Germany saw my (OEM PICTURES ) setup and he told me that it seems Mercedes SL600 use two differenet type of exhaust systems. One that I have and one same as this picture show. He had this at his car and he have removed "undefloor catalytic converters 158". So now we all know how it is...
#17 |
Drives: CL55 AMG
I have an 03 CL55 & i want to make some changes to the exhaust. What sort of sound would I get from removing the secondary cats and resonators ONLY ? Would I see power gains from doing that? Any suggestions? should i set up an x-pipe instead of the secondary cats or not. I will leave the primary cats to avoid any problems with the O2 sensors.
thanks |
| Tags |
| car, cat, cm30, diagram, engine, exhaust, exterior, labeled, mercedes, parts, removing, s600, sl65, v12, w220 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
