Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > SL55 AMG, SL63 AMG, SL65 AMG (R230)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
SL55 AMG, SL63 AMG, SL65 AMG (R230) Discuss the SL55, SL63 and SL65 AMG.
Sponsored by Global Autosports
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-27-2012, 11:09 AM   #1
thill381's Avatar
Drives: SL55
Climate Control Jacked Up
I took out the center counsel to wrap it in carbon fiber and after reinstalling everything I can't change the temperature or direction of air flow on the climate control. The fan speed control operates fine but the air is blowing from the vents and the foot well and I can't change it. No matter if it is set to auto or I try to adjust the air flow manually it won't change from blowing out both the footwell and dash vents.
I did notice I broke a small tab that held in a flat wire with about 5 strands wide and pinched it into metal pins. I seated the wire back into this clip and hot glued it in place. I wonder if not all wires are making contacts with the pins.
Any suggestions?
To remove this ad, register today or login if you already are registered!
__________________
Tim
05 SL55- lightly modified
10 RX350 (wifey's)
10 911 Carrera S (sold)
07 911 Carrera S (sold)
08 Z06 (sold)
07 SLK55 (sold)
05 Corvette (sold)
thill381 is offline   Reply With Quote
Old 04-30-2012, 07:00 PM   #2
nir
Drives: 2003 SL 55 AMG
I had similar problem when installing new radio but my center vents did not work. pulled out the center console cover around the shifter apart and one of the wires were not seated correctly - maybe your problem is similar - check the wires correctly.
__________________
SL 55 AMG
nir is offline   Reply With Quote
Old 05-01-2012, 07:09 AM   #3
thill381's Avatar
Drives: SL55
Thanks for the reply I will double check the wires.
__________________
Tim
10 RX350 (wifey's)
08 Z06 (sold)
07 SLK55 (sold)
05 Corvette (sold)
Old 05-11-2012, 07:14 AM   #4
thill381's Avatar
Drives: SL55
So the saga continues. Now I have noticed that not only does the air only come out of the vents, none of the vent control wheels work. The two center vents and the drivers side vent all have air blowing form them but the passenger side vent does not and you cant control any of them with the wheels under the center vents. the only wire that was not connected properly was a flat wire (part# 230 820 0215) that is pinched through 8 pins on the back of the climate control unit. I was able to reset this wire and that made things worse. With this wire reconnected I could not control the any function of the HVAC system and the fan would continue to blow with the car off and the key out of the ignition. I disconnected the battery to try to "reset" it and this did not work either. I have since removed the flat wire again so that the blower does not stay on constantly.
I don't think it is the climate control unit itself as I can adjust the fan speed and turn it off. It has something to do with where ever the flat wire goes which I believe is to the vent control wheels.
Any other ideas?
__________________
Tim
10 RX350 (wifey's)
08 Z06 (sold)
07 SLK55 (sold)
05 Corvette (sold)
Old 05-13-2012, 11:23 PM   #5
alx
The vent control wheels are not mechanical- they control stepper motors that open and close the vent flaps.
Disassemble everything again and start measuring continuity with an ohm meter- this will tell you if you Nicked something. Check also carefully all connectors. Obviously make sure ignition is off. I would disconnect also both batteries just to be safe.
My guess is that you have forgotten to plug in something somewhere. There are a lot of connectors in there. Some are under the head unit.
alx is offline   Reply With Quote
Tags
03, 2004, ac, climate, control, controller, knob, manual, mercedes, nick, problems, r230, reset, sl55, unit, w220
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
