Sign in using an external account
| SL55 AMG, SL63 AMG, SL65 AMG (R230) Discuss the SL55, SL63 and SL65 AMG. Sponsored by Global Autosports
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Whining sound from Sl65
#2 |
I've noticed the whine happens on deceleration also. I'm thinking it might be transmission related. Sound doesn't seem to come from rear (differential). Dealer will diagnose next week I guess.
Anybody else experience similar?
__________________
05 SL65 |
#3 |
Drives: SL 65 AMG, Porsche 911 (993), 2011 Prius 5, 2013 Toyota Highlander Limited
keep us posted
Let us know......what is found.....maybe bearing issue of some kind...
My transmission sometimes winds up and winds down with some extra whining noise
__________________
2005 Brilliant Silver/black-charcoal SL 65 AMG 1995 Grand Prix White/cashmere/blue top Porsche 911 Cab - 993 2011 Blizzard White/Sand Beige Prius 5 2013 Toyota Highlander Limited 4WD
#4 |
Drives: 07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Check the ABC/ Tandem pump.
Good luck. Aaron |
#5 |
Have them check rear diff fluid level as well as tranny fluid level. You might have sprung a leak.
#6 |
Thx for the ideas guys. I've noticed the whine occurs even when car is at rest and in neutral gear. So, I'm assuming that eliminates transmission & differential. Car goes to dealer on Wed and I'm not driving it.
I'm praying it's not main engine bearing (can you tell I'm a worrier)? :\
__________________
05 SL65 |
#7 |
Drives: 03SL55
Bearings make a knock noise. Whine usually comes from gears.
#8 | |
Quote:
have the tranny fluid checked. also, it could be something under the hood. it could be a pulley bearing, a belt, a water pump, a tandem pump, alternator, a/c compressor... etc... best to pr1ck your ears and listen carefully
#9 |
Thanks for the further suggestions guys. It definitely does sound like a gear type whine. I'm not accustomed to having such a 'turn-key' car that dissuades the owner from checking tranny fluid unless they are armed with a special tool. Does an error message post to dash when tranny fluid gets low?
SL is into dealer on Wed.
__________________
05 SL65 |
#10 | |
Quote:
let us know what you find
#11 |
#12 |
Whining is a transmission issue. Dealer is swapping out entire trans with new one. I'll get details next week when I pick my car up.
CPO + extended warranty is paying off as this will not cost me a penny. Biggest question is what caused this issue at 30k miles. I'm not rough with my cars. This is previous owned car and you never know how the prior owner may have treated it. From what I hear, the tranny in the SL65 is supposedly rock solid. I'd expect more issues to surface with the newer 7sp tranny than this tried & true.
__________________
05 SL65 |
#13 |
Definitely report back when they are done. Hopefully they are not guessing. Not that it matters anyways since you don't have to pay anything. So regardless, a new tranny is a good thing.
The reason i mentioned the pump is because i have heard a similar issue first hand with a whining sound on accel and decel which sounded tranny related. It tuned out to be the tandem pump after alot of troubleshooting. Good luck. Aaron |
#14 |
Update - The dealer replaced the whole transmission and torque converter. I'm pleased that their policy is to replace transmissions rather than tear them apart and try to fix the specific issue. They leave transmission internals to the Mercedes transmission experts. When you think about it, the transmission is probably more complex than the engine internals.
They discovered some metal flashing in the pan but I'd think you might find some metal filings in any trans? Anyways, my SL is CPO with extended warranty until 2014 so this repair costs me 0$. They also replaced a leaking rear ABC strut, bled the system and aligned my car for 0$.
__________________
05 SL65 |
#15 | |
Quote:
#16 |
So it's fixed? Good to see a warranty company not trying to get out of repairs.
Aaron |
#17 |
Drives: 2009 SL 6.3 AMG, 2011 E350 Convertible
Whining Sound
Please let me know what you find out. My SL 6.3 AMG is making the same whining sound. Started 2 months ago and is driving me crazy.
When my transmission is disengaged (Neutral) I dont hear it. Last edited by C Rob; 10-05-2012 at 03:00 PM. Reason: More information |
| Tags |
| 63, abc, amg, bearing, diff, mb, mercedes, noise, pump, r230, sl, sl65, transmission, whine, whining, world |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
