SL55/63/65/R230 AMG: My new Mars RED SL55 | lowered with Radenergie R10 | PICS
Rating: Thread Rating: 3 votes, 5.00 average.
Old 11-02-2012, 02:00 PM
  #76
RonnieRenaldi's Avatar
SL55 AMG & BMW F10
My black intercooler and huge Meziere pump
CF steering wheel (paddles already installed btw, will take pics later):
Old 11-03-2012, 06:57 AM
  #77
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Ronnie if you have access to a fab shop, have them remove the drain valve on the ic and weld the opening shut. Without the valve you will have no clearance issues with the front bumper.
Old 11-03-2012, 02:00 PM
  #78
overZealous1's Avatar
sl55 amg
^ i just used a plug. if you use an allen head one it will sit pretty flush.
looks good ronnie.
Old 11-06-2012, 04:22 PM
  #79
SL55 AMG & BMW F10
looks good ronnie.
What kind of plug? Can I buy it somewhere?
Thanks btw.
Old 11-06-2012, 05:41 PM
  #80
kustom2k1's Avatar
03SL55
Ronnie, can you post pics of the Mez pump mounted and give your opinion on the pumps noise level. Thanks.
Old 11-06-2012, 08:27 PM
  #81
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Thanks btw.
aluminum NPT (probably 1/2 or 3/8)
here is an assortment that would have you covered for $9
http://www.summitracing.com/parts/sum-g1484
edit ... looking at the picture a little more closely, I'm going to guess again and say it looks to be 1/4 NPT ... your local speed shop should have these (hanging on the wall next to their aluminum AN fittings)
Chris
Old 11-06-2012, 09:03 PM
  #82
sl55 amg
i am pretty sure it is 1/4 pipe thread. i think i just used a square head brass one from home depot, lol. the allen head one would sit almost flush though.
Old 11-07-2012, 07:07 PM
  #83
i just pulled a FB HE out of the box and can confirm that the plug is a 1/4-NPT
considering the "heft" of this HE ... steel or brass seems in order.
I would go for a flush style plug (allen or square-drive ... 2 plugs on left in pic)
Attached Thumbnails My new Mars RED SL55 | lowered with Radenergie R10 | PICS-2012-11-07_15-53-04_194.jpg
Old 11-09-2012, 11:41 AM
  #84
Ronnie,
one more idea for your H E drain/plug .
if you have the flexibility in your mounting area relative to the vendor installed mounting tabs (or you are removing the mounting tabs and welding on more application-specific tabs like I am) ... you should consider mounting your HE with the drain bung UP (see pic I shot yesterday right before I removed the "Tabs"). this way the bottom of your HE is clean AND you can use the hole to bleed out the air on your initial fill of the system.
Chris
Attached Thumbnails My new Mars RED SL55 | lowered with Radenergie R10 | PICS-2012-11-08_17-55-21_378.jpg
Old 11-14-2012, 01:31 PM
  #85
on second thought (what was I thinking?) i would source aluminum plugs (both the 1/4 NPT for the drain AND the 1/8 NPTfor the temp sensor bung) AND I would recommend aluminum hose-barbs. Steel is not so good here and .... Brass and aluminum together in a cooling system can (will) lead to aggressive Galvanic Corrosion issues. It would be a shame to bugger up the IC (mounted under the supercharger) due to saving a few bucks on fittings.
Chris
Old 11-14-2012, 02:54 PM
  #86
SL55 AMG & BMW F10
Thanks for all the input guys, I forwarded these to my mechanic. He's doing the install this week.
Old 11-16-2012, 05:59 PM
  #87
SL55 AMG & BMW F10
SC is out...
Old 11-20-2012, 01:21 PM
  #88
SL55 AMG & BMW F10
Got my new CF shift knob with custom leather with red stitching boot, but the base of the boot is wrong!
Now need to find a good upholstery shop to swap the boots.
Old 11-20-2012, 08:21 PM
  #89
sl55 amg
that sucks. not even close to right. have you checked to see if knob fits correctly. do that first. atleast it is bigger and not smaller. should be an easy fix.
Old 11-26-2012, 04:30 PM
  #90
SL55 AMG & BMW F10
that sucks. not even close to right. have you checked to see if knob fits correctly. do that first. at least it is bigger and not smaller. should be an easy fix.
Good thing the new knob fits perfect, I just found a local upholstery shop that can do the boot swap for $65.
Old 11-26-2012, 07:31 PM
  #91
0veRRateD's Avatar
SL55 AmG, Lexus IS350, Infiniti G35
Looks good, Ronnie!
Old 11-27-2012, 10:32 AM
  #92
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
Love the upgrades... car looks stunning !
Old 11-29-2012, 09:28 PM
  #93
SL55 AMG & BMW F10
82mm TB:
BWK:
Old 11-29-2012, 10:05 PM
  #94
sl55 amg
looks good man. thats the audi one correct? you will probably have probs getting the stock intake tubes to fit. i couldn't get mine to work and the main reason i had to fab up the silicone couplers.
Old 11-30-2012, 08:02 PM
  #95
jagata's Avatar
S6 LP640 E500
Originally Posted by B R
Looks good, now go paint that drywall in your garage!
2 words, GARAGE CABINETS. JK
Love MARS RED.
Old 12-03-2012, 04:40 PM
  #96
SL55 AMG & BMW F10
Don't know, I bought the 82mm TB kit from Shardul.
Old 12-03-2012, 04:56 PM
  #97
SL55 AMG & BMW F10
Some recent pics:
Old 12-05-2012, 01:18 AM
  #98
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
Looks great, when are you getting the new mirrors installed?
Old 12-05-2012, 04:00 AM
  #99
SpiritR230's Avatar
2015 SL63 AMG
LOL RaFFi, you're all about the details~ I know you're just looking at it and thinking about yours, right?
Old 12-05-2012, 08:49 AM
  #100
AmmarYasirA's Avatar
W219 CLS63
MMMM, tasty, the updated mirrors + black headlight inlays would set the car. it'd be all done.
But if you dont want the inlays, you could put a dab of chrome on your grill. Like the 3-fin you showed us with the chrome slits, EXCEPT- make the silver part black.... IMO- the car would be finished..
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: SL55/63/65/R230 AMG: My new Mars RED SL55 | lowered with Radenergie R10 | PICS
