SL55/63/65/R230 AMG: Leaking boot
Old 11-18-2014, 03:12 PM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Leaking boot
I think most SL's leak a bit in the boot. Any body got any tips to stop the
leaks, apart from a rain dance..
Old 11-18-2014, 03:52 PM
JohnH's Avatar
2004 SL55 AMG
You need to regularly treat the rubbers with silicone spray to make sure they dont go brittle. I use Aerospace 303 Protectant but quite a few available.
Old 11-18-2014, 04:27 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Sounds like the rubber seal where the roof and the trunk meet is going back, I had the same issue in the summer
Old 11-20-2014, 10:44 AM
sound 8's Avatar
Thanks guys..
Does your rubber trim have 2 holes ( I think there suppose to be there )
on the rim that runs along the base of the roof line, quite often there is
water on the cover under where these holes are when I open the trunk/boot
.. It must drip down from these holes, shall I block them, they must be
there for a reason.
Old 11-20-2014, 10:49 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
+1 on this!
Old 11-21-2014, 01:01 AM
It doesn't drip through the holes, the seal over time will sag allowing water to pass through any gaps and drips into the trunk
Old 11-21-2014, 09:21 AM
sound 8's Avatar
I just realised there is something else, my guy who cleans my cars uses
a high pressure washer.. not any more
Quick Reply: SL55/63/65/R230 AMG: Leaking boot
