SL55/63/65/R230 AMG: latest part number for front struts and estimate cost
Old 12-21-2014, 10:09 AM
dinkyboy1's Avatar
SL55 AMG
My car is lowering from the front left side (front and rear). ABC light in white is also coming up on screen. I have replaced the front valve block. The problem is still not solved. So i showed it to a new garage. After diagnosing the car, i am informed that the problem is in the front left strut. This could be possible as the front left strut was opened by my old garage. I am certain that he does not have the tools to fix the hydraulic strut and has messed it up. I am informed that i will have to replace both the front struts. Could someone please help me with the latest part number for the strut and also link to a good website where i can purchase the part.
Old 12-21-2014, 01:43 PM
Ingenere's Avatar
2003 SL55 AMG, 1989 348 Challenge, 1987 Testarossa, 1992 F40, 1989 Mondial t cab, 2001 X5 4.4 Sport
You have 2 choices that I am aware of:
1. Go to the dealer, give them the VIN and they will get you the shocks. ~$2K each.
2. Contact these guys that rebuild them for $600 each.
https://www.arnottindustries.com
Old 12-22-2014, 09:15 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Arnott has a great aftermarket strut. We have used them a lot.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 12-23-2014, 08:36 PM
abiazis's Avatar
SL 65 AMG, Porsche 911 (993), 2014 Cayenne GTS, 2013 Toyota Highlander Limited
Arnott is guaranteed lifetime while MB struts are not......installed one in front, no issue.....also much less expensive.......and better built.......
Old 01-04-2015, 11:19 PM
coldhammer's Avatar
2003 SL55 Klemman
i used arnott. great product. also given that your car is sagging front and back you probably need to replace both or rebuild both valve blocks. not just the front. If i recall front is controlled by one block rear by the other.
Quick Reply: SL55/63/65/R230 AMG: latest part number for front struts and estimate cost
