SL55/63/65/R230 AMG: 2007 sl55 AMG 030 rotors and pad replacement
2007 SL55 w/ 030
Just got a 2007 sl55 with the performance pack, I was looking around at reviews onthe car and saw the brakes and rotors are a costly repair . My question is , are there any aftermarket parts for these cars? Also , all my Bmw vehicles that I recall had the brakes and rotors replaced at the same time , never just the pads. Would this be the case for this car as well ? Generally speaking about how long do the rotors last ( miles) before they need replacing ?
Thanks for any help
JZ
Thanks for any help
JZ
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Only aftermarket replacement is racing brakes. The brakes you have are 2 piece brembo brakes that's also used on the SL65 as standard brakes. Or you can go to
https://www.mercedespartscenter.com/...?siteid=215720
And get them off about 25%. It's a dealer in Kansas.
Front's only last about 40-70k depends how you drive, rear can last up to 100k np
You wont need replacing until you get a visit workshop for brakes.
how many miles are on it, you dont need to replace the rotor unless it needs it, there is a wear limit thickness. from my experience you may get away with 2 sets of pads to 1 set of rotors
Former Vendor of MBWorld
RB has the following offer for SL:
Front: http://www.racingbrake.com/Two-piece...ONT-p/2237.htm
Rear: http://www.racingbrake.com/Two-piece...EAR-p/2236.htm
Both are in stock for shipment upon order, if order the complete car kit there will be a saving of 10% over purchase individually.
