SL55/63/65/R230 AMG: Valve Block Replacent Issue!?
Just replaced the front valve block & now Car has just dived up front & the whole car won't raise!? The rear is still up with front pointing down & whichever button I try to raise, nothing happens
Tried Bleeding the fluid by the usual method of raising/lowering via the button; nothing. Also, tried bleeding at the nipple closest to the front valve block; nothing came out!
Might just try the old valve block as that had none of these symptoms?!
