SL55/63/65/R230 AMG: 20 inch wheels on sl65
Old 01-18-2016, 11:20 PM
supermoss's Avatar
sl63
Will it affect the speedometer on a 2007 sl65 to put 20 inch sl63 wheels on it?
Old 01-19-2016, 12:21 AM
boostd's Avatar
2005 SL65
The correct +1 is 255/30/20 front and 305/25/20 back. As long as you have these size tires, your speedo will be accurate.
Old 01-19-2016, 06:46 AM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Use the tire size calculator under tools on this website (or google search the term)
Old 01-19-2016, 09:38 AM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Do you realise by fitting 20 inch wheels you will loose POWER
According to those in the know...
S8
Old 01-19-2016, 11:06 AM
supermoss's Avatar
sl63
S8
You won't lose any power, it just will produce a higher top end like going to a lower numerical rear end gear ratio. In this case I don't think the loss in stop light to stop light quickness will be noticeable.
Old 01-19-2016, 11:15 AM
boostd's Avatar
2005 SL65
Depends on unsprung weight, actually. If the 20" setup is heavier, you'll lose some power.
Old 01-19-2016, 12:52 PM
byronburns's Avatar
2003 sl55
ride
The ride will suffer. I have 20" vossens. the tire sidewall is so short. It makes for a harsh ride. I actually tried to get 19" ones. they won't fit over the front calipers. Good luck. they will look great
Old 01-20-2016, 09:28 AM
sound 8's Avatar
Nothing to do with gearing, for some reason a bigger wheel will loose
power, this was discussed at length a few months back.
S8
Old 01-20-2016, 09:35 AM
supermoss's Avatar
sl63
S8
Opinions vary so lets just leave it at that. Thanks for your input though but my concern was only how it would affect the speedometer. With 600+hp power to the ground is not really a concern. I went from 20 to 19 on my TT Porsche and felt no difference.
Old 01-20-2016, 10:00 AM
boostd's Avatar
2005 SL65
Speedo is affected by overall diameter only.
Old 01-20-2016, 12:07 PM
supermoss's Avatar
sl63
I will use the tires you suggested. Thanks so much for the info!
Old 01-31-2016, 04:18 PM
Jan T's Avatar
Sl65, SL600 RENNtech, Verde Ithaca LP640, 3 highly modified Panteras, Maserati Biturbo, 300D turtle
Yeah, tire calculator works best for determining size. While at it, maybe consider 20 front 21 rear. Gives it a bit more rake appearance.
Quick Reply: SL55/63/65/R230 AMG: 20 inch wheels on sl65
