SL55/63/65/R230 AMG: Rear End Wobble- UPD Suspension kit SL5
Old 04-06-2016, 09:18 AM
Btown715's Avatar
2003 SL55 AMG
I have a 2003 SL55 with 25k miles. It has been serviced 100% with zero problems until now.
I just had a shop install the UPD lowering suspension kit on my car with a new alignment and new rear tires. The front tires have about 4-5k miles and have some pretty uneven wear from lack of alignment and lowering the car. The car drove perfectly straight prior to the kit, I had this kit installed to stop the excessive rear tire wear. It appears the car is lowered around 1.5"-2" with lowering links. I have staggered 20" rims with 245/30/20 and 305/25/20's on the rear.
The problem is since I picked it up from the shop it’s almost like the back end dog tails back and forth just very slightly at highway speeds over 40 mph and wants to go in a different direction then the front end.
It’s kind of scary. Would this be the bushings? Is the kit installed correctly and is their a common fix? Would uneven front tire wear really move the car like this?
Old 04-09-2016, 10:00 PM
m-svt-amg's Avatar
2003 SL55
I experience this as well. By any chance is your rear strut leaking?
If not, check your alignment. Its likely your toe settings arent where they need to be if you have instability at high speed.
Old 04-11-2016, 11:47 PM
gwelliott's Avatar
SL600
OK...I don't feel like a moron now.
As many know I did an ABC delete and installed coilover on all four wheels. I switched from 20" back to 18"'s to get better ride quality and feel the same effect. It is almost like the car feels like it hits a rut in the road and moves the rear end around. The car corners like it is on rails, but the slightest imperfection in the road makes the rear squirrely.
I thought it was the coilovers and thought I would have to live with it, but now I am not so sure.
P.S. It seemed to get worse when I added spacers to the front wheel to help with clearance issues with the new sway bar.
Old 04-12-2016, 01:05 AM
m-svt-amg's Avatar
2003 SL55
Ya, sounds exactly like mine. Maybe its a bad diff?
Old 04-14-2016, 07:10 PM
gwelliott's Avatar
SL600
I have and LSD on my living room floor that is going on in a few weeks. I'll let you know if that helps.
Old 04-14-2016, 10:37 PM
Btown715's Avatar
2003 SL55 AMG
So I called Shardel at UPD and he shipped me fixed toe ends for his kit. Probable fixed!
Old 04-14-2016, 10:39 PM
m-svt-amg's Avatar
2003 SL55
Please let us know if it helps, i will do the same if it is successful for you!
Old 05-20-2016, 11:10 PM
Atk_gaming's Avatar
2005 e55 amg, 2005 audi s4, 2000 audi a4 1.8T (big turbo)
Oh
Old 05-20-2016, 11:15 PM
m-svt-amg's Avatar
2003 SL55
Hey btown, ever get the new links installed?
Old 07-30-2017, 06:39 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Did the new links fix the problem?
Old 04-22-2018, 07:35 AM
j487's Avatar
Toyota Corolla
1
Last edited by j487; 04-23-2018 at 03:55 AM. Reason: Accidentally posted in the wrong thread
Old 04-28-2018, 10:04 PM
layzie12g's Avatar
2008 Mercedes Benz E63
Old 05-19-2018, 07:47 PM
gwelliott's Avatar
SL600
Apologies for not following up sooner to anyone that had this problem, but mine surfaced after I switched from 21" wheels back to stock 18's. I had an alignment done, so I didn't think that was the issue, but I after several months of this weird rear-end wobble I took it to a more competent suspension shop. They re-aligned and the problem went away.
Just to be clear, my car no longer has an ABC, so I am running a rear sway-bar which could have exacerbated things.
Quick Reply: SL55/63/65/R230 AMG: Rear End Wobble- UPD Suspension kit SL5
