SL55/63/65/R230 AMG: Softclose boot fail
Old 06-05-2016, 11:53 AM
SL502's Avatar
SL55AMG-CL55AMG
Softclose boot fail
All ok until today,no noise/hissing or reaction when I close the boot,any idea.Thanks
Old 06-05-2016, 12:18 PM
Rocman8's Avatar
E55
needs a trunk latch. the air diaphragm is leaking. replace trunk latch and clear codes or unplug the pse pump to reset instead.
Old 06-05-2016, 05:12 PM
SL502's Avatar
SL55AMG-CL55AMG
Thanks.
Old 06-05-2016, 05:13 PM
Ingenere's Avatar
2003 SL55 AMG, 1989 348 Challenge, 1987 Testarossa, 1992 F40, 1989 Mondial t cab, 2001 X5 4.4 Sport
Where is the pse pump?
Old 06-05-2016, 05:50 PM
Rocman8's Avatar
E55
Left of spare tire underneath the hardtop hydraulic pump. It's wrapped in foam.
Old 06-06-2016, 09:26 AM
kittyandgary's Avatar
2003 SL55 AMG
It also could be the 'air' motor in the lid of the trunk that failed. They are notorious for developing cracks that allow leaks. I have a repaired one that I'll sell (I bought a replacement when mine failed, but it had small leaks, so I repaired it and the OE one in my trunk, re-installed my OE one 3 years ago and the soft close works perfectly). Send me a PM or e-mail if interested in a repaired one that is guaranteed to have no leaks.
Old 06-06-2016, 11:52 PM
coldhammer's Avatar
2003 SL55 Klemman
can also reset by disconnecting and reconnecting accessory battery. theres a big write up on here somewhere covering what goes wrong with the soft close.
Old 06-07-2016, 12:54 AM
PoCoAMG's Avatar
2018 E63S AMG
Thought I would post here...
...because "soft close" is great for the search function. Related to SL502 (great name BTW) but a bit different. Just don't want to hijack! My brother is a mechanic and he has my car to put in new doors sills and a bi-xenon bulb, but here is what mine is doing. If the hard top roof is up, the soft close will not work on my trunk. The roof will not go back down because the trunk is still "open" according to the switch on the drivers side door. Now he resets it and then lowers the top. When the top is down, the soft close for the trunk works. He wants to look into this deeper but has anyone else had this issue?
Cheers!
Shaun
Old 06-07-2016, 02:24 PM
Nor Cal SL55's Avatar
2007 SL55
Cheers!
Shaun
Just a possibility - research the flap repair - here:
https://mbworld.org/forums/sl55-amg-...y-fix-diy.html
Sounds like The cover flap(s) are loose. With the top down, the flap(s) are secure in their position and the switch see this and works. When the top is up, the flaps hang (inside the trunk) and the switch is "open" causing the error.
A couple of other links for you...
https://mbworld.org/forums/sl-class-...-will-not.html
https://mbworld.org/forums/sl-class-...w-fix-diy.html
Thanks to NikleinR6 and egwu for the write-up and links
Old 06-07-2016, 04:47 PM
PoCoAMG's Avatar
2018 E63S AMG
Hey Thanks NorCal!
Here are pics of the flaps on my SL. The one on the Driver's side is totally broken or shifted from the original. I will look into this and get back to the board. Thanks so much. Cheers!
Shaun
Old 06-08-2016, 12:40 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
no need to disconnect the battery.
just pull fuse F71 (see 20 amp fuse in attached pic) in the rear SAM (storage cubby behind passenger seat) and then re-install ... this will reset the central locking system.
On my 2003 SL55, this soft-close issue only comes up once in awhile, so I made a replacement circuit (plugs-in in place of F71) that feeds the power through a remote 20 amp fuse (see second pic) and the normally closed side of a relay (and I merely push the button to reset the central locking system). One of these days I will look for the leak ...
Cheers,
Chris
Attached Thumbnails Softclose boot fail-20150809_185820.jpg   Softclose boot fail-20160524_193500.jpg
Old 06-13-2016, 10:35 PM
coldhammer's Avatar
2003 SL55 Klemman
Cheers,
Chris
thats a great idea. i only have to reset mine occasionally as well. where did you get the remote fuse setup?
Old 06-13-2016, 10:46 PM
I built it using generic components ... It's pretty simple. PM me your email address if you want more info. At some point, I could probably post a parts list and schematic.
Cheers,
Chris
Got Paddles?
Old 06-14-2016, 05:20 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
you can also rest it with a STAR tool if you have one
Old 06-14-2016, 05:57 PM
SL502's Avatar
SL55AMG-CL55AMG
I did the fuse F71 trick again,and this time the softclose is still working
Ok,I know it must be a leak,can I fix it with glue to seal the lock operator?
Old 06-14-2016, 07:29 PM
PoCoAMG's Avatar
2018 E63S AMG
Follow Up...
Hey fellow MB soft close loose your mind peeps
So my brother fixed the flap (you can see it was pretty off line)and it's still not working (or partially working). With the roof up, the soft close does not work. When the roof is down, the soft close does work. I will follow up with my brother and give him the car again to find the leak. I sure like that circuit Chris made to make the process simple to reset. Nice work! Will keep everyone posted....
Shaun
Old 06-21-2016, 02:22 AM
I just threw together a crude drawing of the soft close reset harness I made for my 2003 sl55.
feel free to ask for clarifications
Cheers,
Chris
Old 06-22-2016, 04:58 AM
SL502's Avatar
SL55AMG-CL55AMG
Great setup Chris, thanks
Old 06-23-2016, 01:38 PM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
Guys,
I haven't see this fix anywhere so I thought I would post my experience.
I got this 04 S430 3 yrs ago and I didn't know anything about soft close until I ran into the info in this forum.
After pulling 20A fuse, rear passenger doors would stay working but front driver and front passenger door would only worked a few times.
I pulled the pump in the trunk but couldn't find anything wrong with it. I keep pulling 20A fuse once a while and finally got tired of pulling the fuse.
Last month, I gave some white lithium grease to the unit and both front doors have been working since then. Not sure how long this will last but I thought I would share. There are video on pulling the panels and it's very easy. I applied the grease without pulling the door actuator. See included pic with white lithium grease.
Anyone out there tried this method?
Attached Thumbnails Softclose boot fail-photo454.jpg   Softclose boot fail-photo629.jpg
Quick Reply: SL55/63/65/R230 AMG: Softclose boot fail
