SL55/63/65/R230 AMG: 82mm Mercedes TB -- What do I do about PCV?
Ok so I recently upgraded to the 82mm mercedes TB sold by a vendor on here.
Swapped my pins, everything seems great but there is no provision for the pcv. All there is, is a large diameter (3/8th?) vacuum port, which we capped off.
I ordered a needswings catch can hoping it would bypass my need for the pcv breather, but apparently not.
Any thoughts?
Any thoughts?
Is the vacuum port you mentioned threaded? If so, perhaps you're meant to screw a barbed nipple into it to connect a hose from the output of the catch can.
Thank you for your reply. I wish I had known or thought of the solution you proposed prior to spending a couple hours reinstalling the Supercharger, and just putting fresh gaskets in, lol.
I think what I will do, is just vent to atmosphere after the catch can, and put a filter on the breather port.
Assuming I never drive the car in winter, I should have no risk of freezing/blocking my PCV system, So I think I'll be alright?
Or does it matter on these motors since we have a second throttle body below?
I am not sure what to think now.
