SL55/63/65/R230 AMG: Weistec SL65 Anti Surge Valve Set
Former Vendor of MBWorld
The Mercedes M275 and M279 Biturbo V12 engines found in the AMG 65 models feature plastic bypass valves that are installed the the compressor covers of each turbo. The bypass valves are prone to leaking, especially on vehicles that have an ecu upgrade with higher than stock boost levels.
Available Now at Weistec.com
Weistec M275-M279 Anti-Surge Valves (ASV) replace the factory bypass valves with a bolt in installation. The system produces the infamous and sought after “blow-off” sound. This upgrade is a must for vehicles that have an ECU upgrade as the factory valves leak and reduce turbocharger efficiency and performance.
KEY FEATURES:
Unless otherwise stated, some Weistec Engineering performance upgrades are sold for race car use only
KEY FEATURES:
- 100% Bolt-On Solution
- No Check Engine Light
- Replaces Leak-prone Factory Bypass Valves
- "Blow Off" Sound
- CNC Machined Aluminum
- Hard Anodized to Military Spec
- Engineered and Manufactured in USA
Speedriven1 (08-23-2016)
