SL55/63/65/R230 AMG: Part number help - fog harness SL65/030 SL55
Im trying to find a part number for the small fog lamp harnesses which connect between the fog lamp h7 bulbs and the main front harness 9006 connectors on 2003-2006 SL65 and SL55 030 package cars.
Attached is a picture of a fog lamp with the jumper harness w/bulb cap attached
this is my best guess ...
it is not in the lighting section of the body electrical (section 82, sub-section 175), but rather in subsection 121 of section 54 .
as you should be able to tell there are MANY part numbers for this harness (item 200) . you need to use your VIN to get the right one.
hope that helps,
Chris
Latemodel 21 Products
hope that helps,
Chris
oops, my bad ... I did not read your post closely enough
this should be it (again, VIN dependant ... but only 2 choices it would seem)
Cheers,
Chris
Cheers,
Chris
here you go.
here is an ebay auction for the H7 version of the fog lamp (used through chassis 122820?) . If includes the harness AND you can see the part number on the harness (A 230 540 38 05)
best price I find is $53 each http://www.mbdirectparts.com/oe-merc...enz/2305403805
http://www.ebay.com/itm/2005-2008-Me...1WRSfc&vxp=mtr
hope that helps,
Chris
hope that helps,
Chris
