SL55/63/65/R230 AMG: SL55 Low Power
Old 01-17-2017, 06:53 PM
joewood's Avatar
sl55
SL55 Low Power
Hello all, 2003 Sl55 40k miles.
Started engine yesterday, low coolant light comes on and goes off, check engine light come on and stays on. It idled fine, but when I try to accelerate engine revs extremely slow as if it has no power. I tried adding coolant, it took about a 1/4 of a gallon to fill. I still have the same results check engine light is still on and power is very low.
Does anyone know what the problem might be?
Thanks Joe
Old 01-17-2017, 07:16 PM
desired_speeds's Avatar
2007 SL55 AMG
Scan for the code first.
Old 01-17-2017, 08:18 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
could be lots of things. Could be a headgasket went bad (rare) and is dumping coolant into the engine causing to to perform bad as well as run low on coolant. Could be when the coolant ran low the car is now not letting the supercharger engage. Either way you need to find out why you are low on coolant and as desired speeds said get the codes read for the check engine light.
Old 01-18-2017, 11:13 PM
joewood's Avatar
sl55
Thanks Guys, I pulled the codes today, the code I have is P0122. So what should I do next?
Old 01-18-2017, 11:19 PM
DUDMD's Avatar
2005 SL65 AMG, 04 S600
Take it into a shop that can properly diagnose this. Could be a bad throttle body/pedal sensor/etc.
That would certainly cause limp mode and power loss. A proper diagnosis should help to find your issue.
Old 01-22-2017, 02:41 PM
Ingenere's Avatar
2003 SL55 AMG, 1989 348 Challenge, 1987 Testarossa, 1992 F40, 1989 Mondial t cab, 2001 X5 4.4 Sport
P0122 is a throttle pedal position sensor.
Quick Reply: SL55/63/65/R230 AMG: SL55 Low Power
