SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: 1999 SLK Climate Control Bulb Replacement???
Old 08-03-2008, 06:38 PM
sgjii's Avatar
I have a '99 SLK230. I know how to get the radio out and the dash apart, from some car audio work I have previously done. My problem is a burnt out climate control ring light. I removed the climate control assembly, noted the positions of the two turn knobs and the two nylon fingers that operate the blend doors. I was hoping for an easy bulb replacement but I have been foiled by the MB design engineers. It appears to be a snap together assembly not meant for servicing. I have gently released the fingers holding the two halves together and have all of thess points free but the two halves won't sperate. I am afraid of the "apply brute force and hope for the best" method. What retainer or fastener might I be missing? Any help, photos, instructions or diagrams would be greatly appreciated.
Oh, I did search "climate control" and some variations in the forum before posting but it didn't pull up anything regarding how to change these bulbs, just a few threads about how they seem to burn out often.
Thanks,
Stephen
Old 08-14-2008, 04:13 PM
bazzle's Avatar
Pull knobs off from the front (Unit still in car)
Lift plastic flap overbulb.
Remove bulb (slide on a bit of plastic tube to remove)
Replace
Bazzle
Attached Thumbnails 1999 SLK Climate Control Bulb Replacement???-knob.jpg   1999 SLK Climate Control Bulb Replacement???-globe.jpg
Old 07-16-2014, 04:34 PM
tektroll's Avatar
SLK 230 R170
bulb replacement
ive been searching everywhere to find this out, thankyou - if this works I will buy you a pint if we ever meet
Old 07-21-2014, 03:08 PM
tektroll's Avatar
SLK 230 R170
it worked, many thanks..... tho fat fingers here had a bit of trouble getting the new bulbs back in.... used the same bit of plastic tube in the end but with a screwdriver gently pushing the bulb top .... otherwise whenever I tried to remove the plastic tube it pulled the bulb out again....
thanks again
Old 07-30-2014, 01:47 PM
Don Mac's Avatar
1998 MB SLK 230
bazzle, I also have a 1998 SLK 230, and bulb burn't out on heater adj. side.
however, when I tried to remove dial selector, it would not come off, is there a trick to remove....(I don't want to break it) Thanking you in advance.....Don
don2425@bell.net
Old 07-30-2014, 01:52 PM
leapyfish's Avatar
2012 E350 75,xxx miles, 1998 SLK230 250,xxx miles
I used a small screwdriver to pry the knob off.
Old 07-30-2014, 02:03 PM
Don Mac's Avatar
1998 MB SLK 230
Thanks, I will give it a try, sure appreciate the advise....Don
Old 07-31-2014, 01:20 PM
Don Mac's Avatar
1998 MB SLK 230
Thanks, it worked fine, sure is nice to get experienced advise.....Don
Quick Reply: SLK/R170: 1999 SLK Climate Control Bulb Replacement???
