SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: SLK230 - cranks but wont start
Old 09-28-2010, 12:53 AM
pbasham's Avatar
1998 SLK230 BAHAMA BLUE
I have a 1998 slk230 with high milage that is my teenage daughters car.
Today it wouldnt start for her when she got out of school. I put jumper cables on it and it would crank just fine, just not firing at all. Got it towed home and after a little research I discovered there was a blown fuse (#11 ignition coil voltage supply) in the fuse box on the right side by the firewall. I put a new fuse in and it cranked right up. I figured a shorted wire is what blew the fuse so I start moving wires from the coils packs (by the fuel rail) and the first wire I touched blew the fuse again, it stalled. Taking a closer look I notice the harness is routed up against a lift hook on top of the engine right before where the harness goes to the coil packs. I peeled the cloth tape back (real brittle when its 13 years old) and found a bare wire that was grounding out. improper tape job and a 20 cents fuse and we're good.
I am probably the only person this could happen to but thought I'd share anyway.
Picture #1 : SLK230 - cranks but wont start-pkb-fusebox.jpg
Fuse box in engine compartment, drivers side (the states) by fire wall. #11 has the fuse out in this picture - right column second down.
Picture #2 :SLK230 - cranks but wont start-pkb-lifthook.jpg Wiring harness to the coil packs by the lift hook on top of engine. It was up tight against the lift hook, this picture is after I peeled the clothtape back.
Picture #3 :SLK230 - cranks but wont start-pkb-fuelrail.jpg
A different angle of harness by fuelrail routed against lifthook to coils.
Picture #4 : SLK230 - cranks but wont start-pkb-barewire.jpg Bare wire -not good. I always wonder how something like this would work out at a dealership shop.
Quick Reply: SLK/R170: SLK230 - cranks but wont start
