Go Back   MBWorld.org Forums > Mercedes-Benz SLR & SL Roadsters > SLK-Class (R170)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-06-2011, 06:11 PM   #1
Drives: 2001 SLK320
DIY for Throttle (Gas Pedal) on 2001 SLK320?
I've searched and searched...ugh. Saw several threads that say "all I did was replace the pedal" Great. HOW did you replace the pedal??
Can anyone help a newbie? I took out the 10mm nut under the cover, and that mudda still won't budge. Is there another attachment point I am missing? HELP!!!
Thanks!
To remove this ad, register today or login if you already are registered!
golfslave is offline   Reply With Quote
Old 01-06-2011, 07:16 PM   #2
buffyclk500's Avatar
Drives: clk500
it should have a parts on the top and bottom
__________________
2003 CLK500-150,000 MILES
AB-RACING:
V2-FULL INTAKE,COOLING SETUP,FULL EXHAUST
KLEEMENN HEADERS
EUROCHARGED ECU/TCU
AMS PULLEY
K.SPORT COILOVER
buffyclk500 is offline   Reply With Quote
Old 01-06-2011, 09:21 PM   #3
Drives: 2001 SLK320
Yeah, but I don't see anything on top. Just the one nut in the middle. Anyone have pics?
Old 01-07-2011, 12:28 AM   #4
Drives: 2004 E500 CLK320
Yeah, I have the same problem removing the gas pedal. After removing the 10mm nut, I still wasn't able to remove the washer. I've seen pictures on older SLK's, the washer was easily removed. But on the 2001 SLK, I couldn't get the washer out -- it's hiding inside that recessed hole and you can't get any tool in to get it out. You may try to jiggle the pedal and pull it straight up at the same time to see if the pedal will slowly jiggle its way out of the bolt.
There's a plastic pin on top of the pedal, you can slide it out w/ a flat screw driver. But removing that pin really doesn't help removing the whole pedal either. I've just ordered a new pedal online. I may end up destroying the old pedal and put in the new one.
SZMB is offline   Reply With Quote
Old 01-10-2011, 05:55 PM   #5
Drives: 2001 SLK320
Anyone else have some info?
Old 01-10-2011, 09:08 PM   #6
Drives: 2001 SLK320
After some doing, I was able to get it out. Know what it was? Elbow grease.
The bolt hole in the plastic housing got elongated horizontally. Since the washer has nowhere to go but with the housing it was jammed tight against the bolt and under the threads of the bolt. Basically, I just rocked the pedal side to side until there was enough play to get a small pry bar under it, then pried it off as straight as I could.
I tested with a voltmeter and there is a short between the two resistor pins (5&6).
Now, where is the least expensive vendor for a new pedal?? Or, maybe a Crossfire PN??
Old 01-15-2011, 08:50 PM   #7
See my other thread in buying the gas pedal. ~$200 including shipping, brand new. Even used ones on Ebay are selling for ~$80 + $70 shipping out of U.K.
http://www.mbworld.org/forums/slk-cl...n-problem.html
Old 12-20-2011, 12:35 AM   #8
Drives: SLK320
Thanks for the info, I had a P0120 DTC on my '01 SLK320, and I replaced the EA accelerator module, and I used a dental pick to remove the washer after removing the 10mm nut. It took a bit of work, but not to bad. also it required pulling aft on the lower EA assy. to remove the upper pin from the support bracket. then I disconnected the 2 connectors (pedal value sensor and kick down switch). This cured my acceleration lag problem. part $200. + $9.shpg from genuinemercedesparts.com
Ricks170.465 is offline   Reply With Quote
Tags
2001, 320, accelerator, crossfire, directions, gas, mercedes, pedal, races, removing, replacing, slk, slk320, throttle, washer
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
