SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Replacement battery size
Old 11-10-2013, 08:15 PM
dillon823's Avatar
2001 SLK 320
All of the sizing guides indicate group size 49 my 2001 SLK 320. However, that size battery is at least 14" long, which appears much longer than my current battery. What is going on? What is the appropriate size for a replacement battery?
Old 11-12-2013, 11:06 AM
spclk60's Avatar
slk320
My advice to you - buy the battery at the dealership. You don't save much money buying at an auto parts store and, when there are problems, your dealer is going to point at the non-MB battery.
Old 08-12-2014, 06:49 AM
wsfahmed's Avatar
2001 SLK 320
Any 74 amp battery should fit. I got a new Bosch battery and it fit just fine
Old 10-16-2014, 02:52 PM
Alex.currie44's Avatar
2009 SLK55 AMG
Ok folks here is the poop, the straight poop and the poop that counts regarding battery size.
I went out and measure mine.
It is 11" long, 6 3/4" wide and 7 1/2" tall. That makes it a group 48 battery.
A group 49 will not fit as it is nearly 14" long. See http://www.batteryplex.com/sheets/BC...with_Cover.pdf
I was mistaken on my battery being an Interstate. It is a World Source One.
As to an OEM battery, if your car is an R170 any dealer schukin' and divin' is irrelevant.
I have been told the WSO batteries are better than the OEM batteries. In my experience any after market battery was better than the Varta batteries they use in the 80's and 90's.
Quick Reply: SLK/R170: Replacement battery size
