SLK/R170: ::ECS Tuning:: Valve Cover Gasket Kit For Your SLK320
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Kits Starting At - $73.54*
Everywhere there is a seam on your engine, there is the potential for and oil leak. This is prevented through the use of gaskets and seals.
One such gasket that prevents oil leaks is the valve cover gasket. These gaskets are used to seal the gaps between the valve cover and the cylinder head, however, since these gaskets are made of rubber they have a tendency to become brittle, crack and start to leak due to its constant exposure to heat and engine oil.
If the valve cover gaskets on your Mercedes-Benz V6 have started to leak, replace them today using this valve cover gasket kit from ECS Tuning. This kit includes everything you will need to replace the valve cover gaskets on your engine and stop those oil leaks.
*Price subject to change.
