SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: 1999 SLK230 CONVERTIBLE TOP STUCK IN RETRACTED POSITON
Old 12-19-2014, 09:02 PM
moose38's Avatar
1999 Mercedes SLK 230
Just purchased a used 99 SLK230. Put top down and everything appeared OK. Tried to put it up and no luck. Still in trunk. Checked fuses - OK - I can hear the motor running. Any suggestions? Thanks - Ray
Old 12-20-2014, 03:57 PM
leapyfish's Avatar
2012 E350 75,xxx miles, 1998 SLK230 250,xxx miles
Here is a link to a troubleshooting guide http://www.benzworld.org/forums/r170...ml#post3582000
Old 12-20-2014, 10:14 PM
moose38's Avatar
Thanks leapyfish. I read a couple of your suggestions and ended up finding a couple of leaking hydraulic cylinders and an empty fluid reservoir. Used a combination of the manual closing procedures and refilling the hydraulic system to get the top locked, the small side windows up, and every thing secured. Will have to remove the leaking cylinders and have them rebuilt at a later date. Appreciate your help - Ray
Old 02-27-2015, 02:35 PM
cornbeef's Avatar
1998 slk230
Smile cornbeef
check your limit switch on the righthand side above the windscreen next to the microswitch
Quick Reply: SLK/R170: 1999 SLK230 CONVERTIBLE TOP STUCK IN RETRACTED POSITON
