SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Mushy ignition, hard to remove key
Old 06-22-2016, 10:49 AM
Gregg Horner's Avatar
slk 230 r170
Do any r 170 owners have a problem with the ignition key not removing? This happens to me about once every 25 times I turn off the engine. I try fiddling with the steering wheel, making sure it's in park, but it just seems to randomly decide to work again, sometimes after restarting the engine several times.
I had the ignition assembly cleaned and lubed but it always feels a bit 'mushy'. Is this normal with these? Would disabling the steering lock mechanism solve the problem? My mechanic had no clue...
Old 09-28-2016, 03:11 AM
Scott Little's Avatar
2013 GLK 250 1999 SLK 230 2002 SLK 230 R170
If an automatic, remove foot from brake before removing the key.
Quick Reply: SLK/R170: Mushy ignition, hard to remove key
