SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: slk320 warning lights
Old 06-27-2016, 06:55 PM
ngpilot's Avatar
slk320 280sl
Hi , Replaced the alternator regulator on my 2003 slk320, the alternator works fine , but now when i turn the ignition switch to the on position, the warning lights on the right side of the panel come on momentarily and go right off. The battery light never comes on . After engine starts voltage reads 14.3 volts.
Anyone out there have a similar problem?
Old 06-28-2016, 11:00 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to R170 forum...
ngpilot (06-28-2016)
Old 06-30-2016, 11:28 AM
zip439's Avatar
CLK 500, yr 2005
When those lights on the instrument cluster come on as you move the ignition key it is my understanding that it is only an illumination test. Perhaps that one bulb has burned out, but it seems strange the light has gone out just after you worked on the alternator. Good luck.
The following 2 users liked this post by zip439:
leapyfish (06-30-2016), ngpilot (06-30-2016)
Quick Reply: SLK/R170: slk320 warning lights
