SLK/R171: Widest tire on an SLK55 AMG?
Hi, I wanted to know if anyone is running 265/35/18 at the rear. Im currently sitting on 265s, however, I feel like the rear rocks or drags a little when making sharp turns. Is this normal? I haven't driven any other slk55 to know the difference.
SLK55, Mustang 480hp, CBR600rr
I have seen others run that size tire, but not sure of offset being used or brand of tire. Since, all tires can be slightly different in height and width even with the same sidewall spec.
Pp
Pp
like Ppower says it probably depends on brand. I know falken and hankooks have round side walls so you can probably fit 265's or maybe 275's however if you have something squared then maybe its rubbing a little?
What brand of tires you running and are you lowered?
I have 2005 slk55 amg.I just bought new tires, front are running 225/40/18 and rear 265/35/18.its not low yet ,but I like to put some wider wheels but keep the tires at the same time.should I use negative 0ffset? zero offset or positive offset.need help on specific size.loking for stile too.any one can help me please thanks a lot.
