SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: SLK 200 R171 cockpit electronics fail
Old 06-01-2016, 01:38 AM
wbeetge's Avatar
SLK 200 (R171)
After starting, the instrument panel, indicators, radio, roof, etc electronics fail. The inside of the car is dead, but the engine seems fine.
Fisrt time, I did not notice, until I got to the first stop and had to use my indicator to turn. It was dead. Not knowing what was wrong, I drove until I got to work. Switched off the car end switched it on again. The problem disappeared. This has been happening a few times now, but it is happening more frequently. It did this 3 times since yesterday. I have a gut feel it is the battery that is on its way out (10 years old) not giving enough current after starting. Has anyone had same issues ?
Old 06-02-2016, 08:17 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Sounds like you either have a faulty ignition switch or a front SAM---the quick way to solve the problem is get the car diagnosed by someone with factory or equal soft ware---if you see sheep\goats grazing out back---move on!!----or sell the car!!
Old 06-10-2016, 03:38 AM
wbeetge's Avatar
SLK 200 (R171)
Thanks Plutoe. I'll have it checked out.
Quick Reply: SLK/R171: SLK 200 R171 cockpit electronics fail
