SLK-Class (R172) 2011-Present SLK200, SLK250, SLK350, and SLK 55
SLK/R172: Brake job DIY
Old 12-19-2016, 06:55 PM
Chef Evans's Avatar
2013 Mercedes Benz SLK 250 AMG Sport Package
Brake job DIY
Hello everyone,
I am upgrading my brakes to carbon ceramic pads and while I'm at it I am going to paint the calipers. I've done a number of brake pad replacements on various vehicles so i'm comfortable with the install and I've researched it online so i'm good to go - but I like to be overly cautious when it comes to my ride, so if anyone here has done their own brakes and has any input/conventional wisdom to offer i'm all ears. I'm familiar with going into the service menu and putting the brake system into the service position before starting. I'd just like an idea of what to expect.
Thanks,
Chef
Old 04-15-2018, 06:21 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK350, 20 S560, 08 Bentley, 14 Porsche Cayman S
I’m going to replace the front brake pads with ones that make less dust. Any diy or help would be appreciated.
Old 04-22-2018, 10:46 AM
Wessel's Avatar
SLK250
I'd like to do the brakes also. Is there a "DIY" section that I'm missing on this board?
Old 04-18-2020, 10:16 PM
beeguz's Avatar
2001 SLK 2017 Chevy Bolt, 2019 Subaru Crosstrek
Brakes are no big deal the only thing that is different on these cars is the sensor that tells you when the pads are low.
the sensor wire just slips into a hole on the top of the pad.
If the cars brake light is on because the pad surface is low, those sensors need to be changed, they are not expensive but only buy new if you really need them.
Otherwise its a straight forward pad change just like you would do on any other car.
Quick Reply: SLK/R172: Brake job DIY
