05 SLK350 Needs replacement power steering rack. $2500 ouch!
05 SLK350
I am bummed out. I store my car all winter for the most part. January, I took a drive to keep everything working and came back with a leak for the power steering rack. I bought the correct fluid and topped it off. Started it up and it proceeded to dump it all on the floor. Well I reconnected the trickle charger and waited until this week to have it flatbed hauled to the Mercedes dealer. This SLK350 only has 17,000 miles on it. I got a call from the dealer and was told the steering rack has a seal blown on the drivers side. Was told they do not replace seals and only replace the entire rack. Cost $2500 dollars. Is this a problem with this car or am I the only unlucky one?
You might be the unlucky one. I have a 2005 slk350 with 102k and no leaks on the rack n pinion. If your were in SoCal, I can have it done for half the price. Go on yelp.com and find an independent shop since you already know the failure. Good luck
