Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > SLK55 (R171)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
SLK55 (R171) Discuss the SLK 55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-28-2004, 08:30 AM   #1
Send a message via AIM to SLK_Owner2B
SLK55 brakes
Are those 6-pot calipers (w/composite rotors) in the front and 4-pots in the back?
To remove this ad, register today or login if you already are registered!
__________________
2005 MB SLK55 AMG (maybe?)
2003 MINI Cooper S JCW - Pure Silver/Black
2002 Honda S2000 - Spa Yellow/Black
SLK_Owner2B is offline   Reply With Quote
Old 05-29-2004, 02:54 PM   #2
SLK55_AMG's Avatar
Drives: SLK55 AMG
give me 2 hours and I'll tell you!
I got the manual at home, as soon as I get there I'll tell you!
sorry!
SLK55_AMG is offline   Reply With Quote
Old 05-30-2004, 02:59 AM   #3
Felix's Avatar
Drives: C-Class
Send a message via ICQ to Felix
Quote:
Die schwimmend gelagerten, innen belüfteten Graugussscheiben mit einem Durchmesser von 340 Millimetern sind mit einem Aluminiumtopf verbunden und stellen zusammen mit den großen Belagflächen des Sechs-Kolben-Festsattels eine größtmögliche thermische Belastbarkeit sicher. An der Hinterachse kommen massive Bremsscheiben mit einem Durchmesser von 330 Millimetern und Vier-Kolben-Festsättel zum Einsatz.
front:
340mm compound-disk, with 6piston-break
rear:
330mm disk with 4piston-break
Felix is offline   Reply With Quote
Old 04-01-2012, 05:27 PM   #4
Drives: 98 W202 C55 KLEEMANN Cams & Headers
Anyone knows whats the height of the SLK55 front Rotor Hat...?, is it 18mm....??
ZAYED,,
cm60k is offline   Reply With Quote
Old 04-01-2012, 07:45 PM   #5
Klinh's Avatar
Drives: Slk55, Clk500 Cab., C350, Civic
Quote:
Originally Posted by Felix View Post
front: 340mm compound-disk, with 6piston-break
The 340mm rotor is standard with 6 piston caliper. The Slk55 "030 AMG Performances Packages" came with 360mm rotors but they're alot more expensive then the standard 340mm rotor. You're looking at about $250-$300 more per rotor.
__________________
Klinh is offline   Reply With Quote
Old 04-01-2012, 08:00 PM   #6
320 dreamer's Avatar
Drives: 2003 porsche 996 turbo
Send a message via Yahoo to 320 dreamer
Quote:
ZAYED,,
within a mm or 2 of the c32 slk32 c55. i have them on my slk32 in 340mm racing brake 2 piece
320 dreamer is offline   Reply With Quote
Old 04-01-2012, 09:25 PM   #7
Thankss for reply guys,, i mean the black piece(which is the Hat) it self,,
i think someone has the pdf file around here with Rotors & Calipers pics. & dia.....
ZAYED,,
Old 04-02-2012, 06:08 AM   #8
ZAYED,,
i was speaking of the hat height. the c55,c32,slk55,slk32 are all within a mm or 2 slk55 hat height is 49mm
Old 04-02-2012, 02:38 PM   #9
I meant the measurement of the HAT only, without the Rotor,, seems like 10mm....
ZAYED,,
Old 04-02-2012, 07:30 PM   #10
Attachment 232201
ZAYED,,
slk55 nominal thickness is 32mm minimum thickness is 30mm. the "hat" is what bolts the rotor to the hub the "ring" is the outer portion the caliper clamps to
Old 04-05-2012, 04:18 PM   #11
My friend made a hat for me "7" months ago, i need to do the same again,, but i forget the Exact size measurement, as i remember, it may comes with
"12mm width & 152mm inner & 165mm outer",, but im not sure if it correct or not..??,, if someone done the same hat, pls. forward the measurement.......
ZAYED,,
Old 04-05-2012, 08:52 PM   #12
Attachment 232519Attachment 232520
ZAYED,,
i will be swapping my drag setup out for my street setup this weekend. ill measure the hats i have on the car then if you want new rotors the racing brake 2 piece rotors for the c32 or a direct bolton for the 6 piston calipers. 340mm and super light. 1000$ for the pair
Old 04-05-2012, 11:03 PM   #13
Quote:
Thankss alot,, good idea about C32 "2" piece rotors, since we got the correct measurement, then its soo easy to fabricate them in any 340mm rotors,,
Good Luck with a drag setup.......
ZAYED,,
Tags
03, 360mm, 55, brake, brakes, c63amg, caliper, dia, pot, r172, racing, rotors, slk, slk55
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
