SLS/R197/C197 AMG: SLS Steering Vibration 120km/h +-
SLS AMG 12' LeMans Red
Hi,
Just would like to know wether some of us may have experienced this as well, I know roads are bumpy and I can totally feel it.
However just on highways when I am travelling above 120km/h, I felt there is a vibration in the steering, more like going up and down...
Would appreciate some to share their experience about this.
Thank You
Thank You
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
It sounds like it could be a tire or wheel issue. I had a vibration in the front and didn't know what it was, as soon as I put it on my lift I noticed the left front tire had worn it's inside shoulder pretty bad, have a good look for that and also see if you are missing any wheel weights for balance.
1 Post
2011 AMG SLS, K&N Air Filter, Cargraphic Exhaust, Klassen M51R Wheels
Hi,
Thank You
Thank You
Good luck!
Will let you know, did the balance today,
thanks a lot.
gonna take a hunch and say your wheels bent. I have after markets and the stocks i got when i bought my car i thought weregonna be better they were bent so bad at 80 they shook the whole car
did balancing but another full and constant test has not been done,
but a little I suppose,
another possibilities is the kw springs I installed back then..
but wil sure do check, thanks bro,
will do a re-balancing probably for all the four wheels tomorrow (again)..
thank you,
Mine had a vibration that only cropped up above 70mph. Tech said sometimes they don't catch it if it happens at higher speeds.
did the balancing,
there were a slight balance,
did not get to try full run on highway,
but did 120-130 and felt no shaking like it used to before, however not sure because road are bumpy..
