SLS AMG Gullwing (C197, R197) 2010 - 2014
SLS/R197/C197 AMG: :: ECS Tuning :: SLS AMG Headers And Center Exhaust
Old 06-11-2015, 03:45 PM
Former Vendor of MBWorld
ECSTuning's Avatar
2012 SLS AMG
Click HERE to order or for more information.
$6,995.00*
The SLS AMG M159 engine made headlines by achieving a specific output figure (horsepower per liter) that rivals the world's most uncompromising supercars.
ECS is honored to expand upon this engine's exceptional achievement by raising that figure to even more rarefied air.
The New ECS Mercedes-Benz SLS AMG Headers and Center Exhaust utilizes stepped equal-length headers mated to a 3" stainless steel, mandrel bent dual exhaust with X-pipe and 200cpi metallic high-flow catalytic converters to develop a staggering 42 additional wheel horsepower at 5500 RPM.
Fits:
SLS AMG (2011-2014)
*Price subject to change.
Old 06-12-2015, 05:59 PM
NewportSLS's Avatar
SLS AMG
I am going to assume this will not pass California Emissions...... ?
Old 06-14-2015, 12:28 AM
SkforzaGroup's Avatar
S63
those headers are gorgeous..
Old 06-15-2015, 03:27 PM
ECSTuning's Avatar
2012 SLS AMG
NewportSLS,
This system does come with 200cpi metallic high-flow catalytic converters. Considering California does have extremely strict emissions, I can't tell you for sure this system will pass.
David
Old 06-15-2015, 03:28 PM
ECSTuning's Avatar
2012 SLS AMG
SkforzaGroup,
Thank you for the kind words!!
David
Old 06-19-2015, 01:28 PM
ECSTuning's Avatar
2012 SLS AMG
Old 06-29-2015, 02:04 PM
ECSTuning's Avatar
2012 SLS AMG
Old 06-30-2015, 12:06 AM
Tjandegi's Avatar
G63, SLS AMG, Shelby GT350
If you don't mind me asking, why have you chosen to use an X crossing rather than an H?
Old 07-01-2015, 12:04 PM
ML63 AMG's Avatar
CL63 AMG
X-pipe is might better for high rpm air flow as the X actually increases scavenging effects by balancing all the pulses better. It also sounds better than an Hpipe too
Old 07-01-2015, 12:08 PM
ML63 AMG's Avatar
CL63 AMG
Excellent job on the headers guys, fantastic exotic sounding exhaust. One question....
The dyno shows peaks gains of 23hp and 37tq, but you claim 42hp & 41 to respectively. I assume those apply to maximum midrange gains? If so at what RPMs do those respective numbers happen at? Thx
Old 07-01-2015, 03:22 PM
ECSTuning's Avatar
2012 SLS AMG
Tjandegi,
My apologies, I am not sure how I missed your comment yesterday. ML63 AMG is correct . The X-pipe was used to maximize the airflow at higher RPM's as well as maximize performance. Generally a X-pipe will have higher gains over an H-pipe.
David
Old 07-01-2015, 03:37 PM
ECSTuning's Avatar
2012 SLS AMG
ML63 AMG,
As far as the dyno chart is concerned, the peak numbers are measuring the maximum HP and TQ on the dyno run. So for the stock setup we saw 452 HP @ 6500 RPM and 393 ft/lbs @ 4630 RPM (all numbers are to the wheels). After our system was installed we saw 475 HP @ 6500 RPM (+23 WHP) and 430 ft/lbs @ 4730 RPM (+37 ft/lbs).
The maximum gain is where the maximum gain was seen on the dyno. The maximum gains with our system were 42WHP @ 5,500 RPM and 41 ft/lbs @ 5,400 RPM.
I hope this helps clear things up. If there is anything else I can do please let me know.
David
Old 07-01-2015, 03:53 PM
Tjandegi's Avatar
Originally Posted by ECSTuning
Tjandegi, My apologies, I am not sure how I missed your comment yesterday. ML63 AMG is correct . The X-pipe was used to maximize the airflow at higher RPM's as well as maximize performance. Generally a X-pipe will have higher gains over an H-pipe. David
Interesting. I have the stock system but removed the resonators and kept the H pipe. What type of dyno setup did you use for the stock numbers you posted? I would like to do a comparison of if the resonators have any influence on power. Maybe I'll chop the H and install an X and do another comparison as well.
Old 07-01-2015, 04:25 PM
ECSTuning's Avatar
2012 SLS AMG
Tjandegi,
We use a Mustang AWD-500 dyno. Both the stock system and ECS Tuning system dyno runs were on the same day with multiple runs, to make sure the numbers were as accurate as possible.
I hope this answers your question. If there is anything else I am able to help you with please let me know!
David
Old 07-01-2015, 05:54 PM
Tjandegi's Avatar
Thank you! Great system, definitely will keep you guys in mind in the future for more mods.
Old 07-01-2015, 06:18 PM
cls55's Avatar
David
Do you need to remove the subframe to install the headers?
Thank you
Old 07-02-2015, 05:26 PM
ECSTuning's Avatar
2012 SLS AMG
Let me know if there is anything I am able to assist you with!
David
Old 07-02-2015, 05:28 PM
ECSTuning's Avatar
2012 SLS AMG
Originally Posted by cls55
David
Thank you
cls55,
The subframe does not need to be removed to install the headers. Only the front wheels and fender liners were removed for access. If you have any other questions please let me know!
David
Old 07-03-2015, 11:48 AM
cls55's Avatar
cls55,
David
Did you have any issues with the relocation of the O2 sensors?Like erratic fluctuations(RPM)or higher gear lower RPM sputtering?Most of people with long tube headers have this issue.
Thank you
Old 07-07-2015, 10:32 AM
ECSTuning's Avatar
2012 SLS AMG
Thank you
cls55,
We did not have any erratic engine behavior after the installation, or throughout our long term testing.
If you have any additional questions please let me know!
David
Old 07-17-2015, 03:49 PM
ECSTuning's Avatar
2012 SLS AMG
Old 08-12-2015, 03:37 PM
ECSTuning's Avatar
2012 SLS AMG
Old 12-16-2015, 05:14 PM
ECSTuning's Avatar
2012 SLS AMG
10% OFF FOR LIMITED TIME!!!!
$6,295.50*
Fits:
SLS AMG (2011-2014)
Old 12-23-2015, 06:42 PM
Jeff SD's Avatar
SLS Roadster
How many hours labor for installation?
Quick Reply: SLS/R197/C197 AMG: :: ECS Tuning :: SLS AMG Headers And Center Exhaust
