KW Suspension
SPONSOR
KW Suspension
Hello MB World Members,
Please contact us if you're in the the market for some KW Coilovers, we guarantee to be the lowest price in the industry.
Please email or PM us for pricing and availability.
Thank you for your time.
WWW.KW-STORE.COM
KW Street Comfort:
KW street comfort – The most individual sport suspension with maximum comfort
With the individual height adjustable KW street comfort coilover kit a lowering of 10-40 mm can be realized, depending on the vehicle. This way the customer has the flexibility to improve the look, with consideration of bigger wheels and tires. At the same time the lowering has a positive effect on the driving dynamics and road contact. With discreet but effective lowering more spring travel will be left to combine a comfortable spring with harmonic damper, this way the best driving comfort is guaranteed. With this product KW offers the perfect compromise of driving dynamic and driving comfort.
KW Variant 1:
KW Variant 1 inox-line – Perfect Street Performance
Sporty Handling with factory pre-set damping
The ideal system for customers wishing to rely on the experience of our engineers to set the damper setting, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety. The user is then free to decide the best height setting for their use and preference.
KW Variant 2:
KW Variant 2 inox-line – Perfect Street Performance
Sport Handling with adjustable rebound damping
This system intended for the experienced driver who does not only wish to determine the individual lowering of his vehicle, but also wishes to carry out setup adjustments. The adjustable rebound damper allows adjusting the pitch and roll behaviour of the vehicle and therefore the driving pleasure can be adapted to the own requirements.
KW Variant 3:
KW Variant 3 inox-line – Perfect Street Performance
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
KW Clubsport:
KW clubsport – Coilovers for race track and road
KW Clubsport coilovers was developed for customers, who demand a better handling car when participating in track day events, but also require a setup that could be used every day. The Clubsport was specifically designed for the Nordschleife using track day tires. By using the optional adjustable top mounts, the suspension geometry can be adjusted to the requirements of tires and the intended use. The mentioned adjustment options combined with the independently adjustable rebound and compression damping technology allow a suspension setup according to the vehicle load, tire characteristics and different track conditions. KW Clubsport meets every demand regarding a coilover for the usage on the road and the race track.
KW Clubsport suspension kits are independently adjustable in compression and rebound forces and include high performance racing springs. Racing top mounts are optionally available for further performance. KW Clubsport guarantees excellent handling, best performance, highest agility and fantastic lap times.
Our Sales pitch.....
WWW.KW-STORE.COM
KW Street Comfort:
- Maximum driving comfort for a perfect performance and more driving pleasure
- Guarantees more comfort, flexibility and sportive as regular OE sport suspensions
- Comfortable adjustment
- Better handling due to less body roll
- With TÜV tested adjustment range for a individual lowering of 10 to 40 mm
- Trapezoid thread for a easy height adjustability
- High quality damper components for a long durability
- Adjustable rebound damping
- Complete delivery content inclusive detailed documentation for a easy use
KW Variant 1:
- Optimally pre-set
- Sporty harmonious damping technology
- Stainless steel technology "inox-line"*
- Individually height-adjustable
- Lowering range approved by the German Technical Control Board (TÜV)
- Fully finished complete solutions
- High-quality component parts for long durability
KW Variant 2:
- Damping technology with individually adjustable rebound
- inox-line* stainless steel technology
- Individually height adjustable
- Adjustment parameters approved by the German Technical Control Board (TÜV)
- High-quality components for long durability
- Comprehensive documentation for easy use
KW Variant 3:
- Damping technology with individually adjustable rebound- and compression technology
- Infinitely variable rebound damping adjustment
- 14-way adjustable compression damping
- Unique, individually working damping force adjustment
KW Clubsport:
- Height adjustable coilovers
- Performance setup for the racetrack
- Dampers in compression & rebound forces independently adjustable
- Use of high performance linear race springs/li>
- In stainless steel technology inox-line
- Additional available with racing top mounts
- TÜV approval possible depending on the specification
(see references)
SPONSOR
SPONSOR
SPONSOR
SPONSOR
