Sign in using an external account
| Suspension and Braking Suspension and Braking components for sale by members. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 1998 E320
WTB: springs for w210. HELP ME GET LOW!!
#2 |
Drives: 1998 E320
b
#3 |
Drives: 1998 E320
looking for used h&r cup kit. love the height
#4 |
Drives: 1998 E320
ttt
#5 |
Drives: 1998 E320
ttt
#6 |
Drives: 99 E430
Ebaymotors.com. Hell cut them. I did. Look at my page
#7 |
Drives: 01e55blk/blk
u cut stock springs?
how much ?
__________________
#8 |
Drives: 99 E430
Well I cut 2 coils but I would do 1 and see how it looks. I say this because if u want to go with a staggered wheel set up like mine u can still get camber arms and have it aligned for the back and not rub on the outside. With mine I won't be able to get it to not slowly wear the inside because of the drop.
#9 |
Drives: 06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
for the love of G-d... how much does a set of H&R or eibach cost ? Is it really wise to play around with cutting springs compared to getting a set already made and designed that way ? Yes I know not all cars drop the same , " spring pads " they come in 4 different heights !! and I do know some people want to slam the W210 .. but you want to slam it .. is the W210 the best car to do so to ? Arent there a slew of other candidates that are far more suitable for that ?
#10 |
Drives: 99 E430
Your right let's not be different! Everybody on the MERCEDES FORUM go buy a Honda civic and tinker with that! Yes springs don't cost much but you'll probably be throwing or old springs away so who cares. It's one coil!
#11 | |
Quote:
#12 |
I will be the last person on this forum to condone mercedes people buying Honda civics and " Tinker " ....but dont buy a Benz and tinker in it like a Honda ! You might want to re-read what I wrote
#13 |
Drives: 99 E430
Mine sat way to high from factory springs I had got from the dealer and I ***** to them that they were wrong. i had over a 2 inch gap after putting them on over my rims. That's why I did 2 coils and no I don't recommend cutting two.off
#14 |
Drives: 99 E430
Yes I'm new to the site but not Mercedes. I wish I could take u for a ride in my e430 and it would probably surprise many on how smooth it handles bumps.
#15 |
Drives: 1998 E320
thanks ESP-OFF for your input, but i personally don't like cutting springs. that's why i'm looking for a used H&R cup kit or anything else that would get me that low...
#16 |
post some pics of it ..
btw i got know a guy localy who got h&r springs and bilsteind shocks from clk55 and they look almost identical to w210 springs and shocks here are part numbers he wants 350 shipping for shocks and springs maybe can cross ref the part number see if they match H&R springs part number 29377 front and rear Bilstein shocks (2) - F4-BE3-2599-HO Bilstein shocks (2) - B36-1855
__________________
#17 |
Drives: 1998 E320
they don't give me the height i want though
#18 |
Drives: w210 e320 USA spec 99 Mod
hii every body,
i've done the cutting for the stock springs 1 coil in front and 1/2 coil in rear, it was very very easy and safe and the ride hight became very nice and the quality not affected at all Benz springs design is the most safe one to be cut as its totally equal and not having any flattened end but my advice is not to cut more than 1.5 coil for any reason unless you change your shocks with a shorter ones |
#19 |
Drives: 1999 E300D
sorry for taking so long on these.
Again, these are the springs from the cup kit sport and are around a 2" drop. A little bit of oxidation on the bottom a spring or two, but with less then 14k miles these guys are just getting broken in. all boxed up and ready to go. |
#20 |
Drives: 1998 E320
springs
PM'ed
#21 |
Drives: 2000 E320
Let me know if you decide to pass on the springs above.
| Tags |
| coil, coils, cut, cutting, front, hr, low, perch, slam, spring, springs, stock, tyou, w210 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
