CLK63 Brake Upgrade
2016 Chevrolet SS, 2006 Cadillac STS-V
CLK63 Brake Upgrade
I'm selling my CLK63 brakes now that they're off the car. This will bolt right onto any W203, R171, or W209 (non-Black Series), The rotors and pads were replaced with brand new Mercedes parts when I bought these and they only have 12k miles on them so they have plenty of life left. There is ZERO pulsation and they stop very well. I marked the rotors where they came from so they can go back with the same pads they had before. Also included with this are Goodridge stainless braided hoses that is a very nice upgrade. I measured the rotors and they have very little wear on them. The front rotor new spec is 32mm thick and the rear is 22mm thick. I've posted plenty of pictures of everything so you can clearly see everything is in good shape.
RF - 31.47mm
LF - 31.44mm
RR - 21.84mm
LR - 21.79mm
Asking $2300 + shipping.
The calipers weigh 50 lbs. and the box measures 23"x23"x11".
The rotors weigh about 90 lbs. and the box will likely measure 15"x15"x25".
RF - 31.47mm
LF - 31.44mm
RR - 21.84mm
LR - 21.79mm
1 Post
2005 Ferrari F430, 2006 E55 AMG, 2005 C55 AMG (Sold), 2001 E430
What kind of wheel diameter, width and offsets do I need to accomadate these big brakes. I have a set of SLK55 amg Multispokes I want to put on. They are 7.5 x 18f, 8.5 x 18r with offsets of 37 front and 30 rear.
thanks.
thanks.
They should fit fine with those wheels since these brakes are very similar to the optional P030 brakes for the SLK55. The rear CLK brakes are actually the exact same brakes as the SLK. I think the front brakes actually use the same caliper with a different rotor but I could be mistaken in that. I was using these with stock C63 wheels 18x8 and 18x9 with 15mm spacers (they weren't replicas so they were W204 offset).
Beautiful, worth every penny. Someone is going to be a proud new owner of these rare and amazing brakes.
I'm almost certain they will. I made a thread a long time ago asking and I'm pretty sure I was told they would because I kept my stock wheels. I searched for it now and I couldn't find it again for some reason, but I found another thread where Lenin posted back in 2012 and said (in regards to the brakes fitting on a C32) that 18" wheels with the correct offset would be needed and he said he used CLK55 wheels but that C55 wheels would also work.
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Thanks for the reply. I'll do some research...
Harry Madam was using stock C55 wheels on his C32 with the CLK brakes, so they fit. https://mbworld.org/forums/c32-amg-c...d-new-pic.html
03 C32 AMG
91RS
Hey actually I have Harry's car now so she is back on the road all right
Do you know if there is adifference which year Rotors to buy for ny set up? I mean Harry mad the upgrades so I'm just taking over. I need to find out what is the wear limit for rotors so I can maybe refinish them instead of buying them new since they are 160$ a piece right?
