Go Back   MBWorld.org Forums > Site & Forum Support > Test
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 12-26-2010, 09:26 AM   #1
Drives: 1993-190E-2.3-auto
190e or 280e
Hello friends,I am looking for a cheap used MB.There are quite a few out there.I like the 190E and the 280E.I found two that fit my budget.They are both in the low 2 grand range.The '93 190E has 170K mi.The'96 280E has less than 120K mi.Both 6 cyl.Both have everything in working order.Logic would dictate to buy the lower mi.one.I really have no preference .Either one would do. .I'm new to this site and I;m 77 yrs young.What do you suggest?Thanks,Art
To remove this ad, register today or login if you already are registered!
irish2 is offline   Reply With Quote
Old 12-27-2010, 03:53 AM   #2
Drives: C
https://www.facebook.com/AMGpowercom?sk=wall amgpowercom
Hi Art,
both are really great cars. My guess is that the 96 280E was a typo and you meant 86. 86 was the last production year for the 280E and 93 was for the 190E, so that's good.
I can only say from personal experience that you wont be disappointed with the 190E 2.6 as long as you keep up with the maintenance. The engine likes to eat gas pretty fast if you're a fast driver. So if gas cost is important to you, I would recommend the 2.3L version instead.
Between the two cars, I would pick the 190E even though it has higher mileage for the following reasons: newer car, engine has more power than the 280E, and I have owned one myself for 4 years and would definitely buy another one if a need ever comes up.
Also make sure you ask some questions regarding maintenance for the 190E, such as,
-when the head gasket was last replaced
-whether the water pump and water pump assembly is new
-when you test drive the car, listen for any transmission hesitation when going from 3rd to 4th gear.
good luck.
__________________
AMG Power!
Sean S is offline   Reply With Quote
Old 12-27-2010, 05:24 AM   #3
190E or C280
Thanks Sean ,excellent advice.You're right it was a typo,a double typo.Did I say 77 yrs young?The other MB is a '95 C280 w/ under 120K.Now what do you think?Art
Old 12-27-2010, 03:09 PM   #4
Drives: C
No problem Art,
C280s are also nice as well. Between 190E and C280 I would pick the C280 since it has more HP and better gas mileage. The V6 runs a bit smoother than the 190E cause it's a bit of a newer engine. It also has a bit of a larger interior space than the 190E.
The only problems I've heard from the C280 is the engine wiring harness and the transmission. But the 190E has almost the same problems if you don't keep up with maintenance.
Again both are good cars, just have to test drive and check them out.
I would ask the C280 owner when was the last time he did any work on the transmission and the wiring harness.
__________________
AMG Power!
Old 12-27-2010, 05:27 PM   #5
C280
Thanks again for good advice Sean.This will help on my test drive & insp.Art
Old 12-27-2010, 06:06 PM   #6
Drives: C
no problem Art, good luck.
__________________
AMG Power!
Tags
190e, gas, improve, milage
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
