Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > V-Class
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
V-Class V 230, V 280, V 200 CDI, V 220 CDI; Vito: Vito F 108 CDI, Vito F 110 CDI, Vito F 112 CDI, Vito F 113, Vito F 114; Marco Polo: Vito MP 108 CDI, Vito MP 110 CDI, Vito MP 112 CDI, Vito MP 113, Vito MP 114; Sprinter James Cook
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-27-2008, 07:29 AM   #1
Drives: MB100
Sprinter engine 308CDI to 313CDI upgrade
Hi,could someone with good experience explain is it possible to swap complete 308CDI engine (not good for reconditioning ) code 611987 with 313CDI one, code 611981 and what are the eventual difficulties?What is the difference with the turbo,injectors,ignition ,wire harness and computer?Thank you in advance.
To remove this ad, register today or login if you already are registered!
gotza is offline   Reply With Quote
Old 10-28-2008, 06:54 AM   #2
Drives: 190D, 190E 2.6, C240, C43, C220cdi
Injectors are the same, harness is similar. The turbo's are completely different, you'll need the ECU from the 313CDI.
If you can get a front cut then that'll help alot.
you'll need the engine complete with turbo, ECU and the turbo regulating valve (mounted on body). the valve may not be different, but i'm pretty sure it is.
The difference in the engines is in the tuning and turbo. The block, heads, injectors are the same
Ausmbtech is offline   Reply With Quote
Old 11-18-2008, 12:15 PM   #3
Drives: ML320CDI
I think the 313 has an intercooler and the 308 doesñ´t.
Philport is offline   Reply With Quote
Tags
308, 308cdi, 313, 313cdi, cdi, ecu, engine, injectors, mercedes, mp, sprinter, swap, upgraded, upgrades
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
