Sign in using an external account
| W210 AMG Discuss the W210 AMG's such as the E50, E55, and E60 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2007 E63 / 2002 E55K (SOLD)
Rear wheel hop! Yike!
__________________
EVOSPORT ROTORS | KW V2 COILOVERS |
#2 |
Drives: monowiper
you're just feeling ESP kick in, your tires might be too bald? or you're stepping on the gas too hard while it's wet, and you're losing a little traction, your ESP kicks in by applying the rear brakes on the wheels therefore you feel a hop, which in fact it's rear brakes being applied on and off.
if you don't want to feel this "hop" just ease on the throttle a little, be more gentle, with more finesse while driving in rain ![]() or just turn the ******* off and do some doughnuts ![]() don't worry no one installed Impala 64 switches on your rear hahah
__________________
#3 |
Drives: '04 Silverado Z71 - sold all my Benzes and need another!
Are your tires new??? If not then you might want to check them for cupping. That's where the tread is different heights causing tires to hop. Also, make sure they're properly balanced because that could also be a cause.
#4 |
Drives: 2002 W210 E55
Man this has been happening to me a bunch. Glad to know what to look for, and I do believe I need new tires.
__________________
![]() The first of hopefully many AMGs |
#5 |
Drives: 99 E55 de-limited 186mph 381bhp 428lbft
or............ it could be infact what your saying (wheel hop) or as its called axel tramp.... my car suffer's from this at times... depending on grip level of surface.
the only thing to do is back off - DO NOT KEEP IT PLANTED AS IT MAY DESTROY YOUR DIFF!!!!!! this happened alot in my sierra cosworth that was running 410bhp.... it did it a few times and everytime i thought nuts to it and kept my foot down!!!! BANG - BLEW THE PLANET AND SUN GEARS IN DIFF. i have only had it happen a few times in the e55..... luckily ![]() just be carefull.... or it may not be this..... and it may be what the other guys have said
__________________
99 W210 AMG E55 381bhp - 429lbft and 186mph!! sprint booster x-pipe, custom exhaust insulated intakes and air box re-mapped for 98ron fuel 19in alloys H&R springs 2#f 1#r flat bonnet badge custom grill ----COMING SOON----- K&N's Pulleys and Re-map |
#6 | |
Quote:
![]() ![]() My tire are New. I don't actually see it hop but i feel like it hopping. once i feel the hops i back off on the trottle. ESP does kick in everytime.
__________________
#7 |
well.. im going for axel tramp then
__________________
#8 | |
Quote:
Doesn't this normally happen during a hard acceleration? If not, a strong launch with wheel spin and then contact (no more wheel spin after first time) and acceleration is then ok?
__________________
#9 | |
Quote:
This is what I'm thinking what is happening correct me if i'm wrong. Since i lighten the rear out by removing the useless spare tire and the new wheel is lighter by 5lb each and Half tank of fuel no passenger this make the rear lighter so on hard ecceleration there nothing planting the rear down so it hops around til the weight shift to the rear and planted the weight down on the tire than it stop hopping and take off. That my theory ![]() ![]() the other one is that I have a bad rear shocks
__________________
#10 | |
Quote:
#11 | |
Drives: 2005 E55
Quote:
__________________
2005 E55 DESIGNO SILVER 172MM E/C PULLEY, JERRY TUNE, E/C HEAT EXCHANGER, RESONATOR DELETE (X-PIPE) DYNO 459 RWP-545 RWTQ |
#12 |
Drives: 2002 E55
I think it is just the spin and grip. Happens to me to. Also happened in other cars as well. My buddies front wheel drive Honda CRX back in the 80's used to hop all over and his change would come falling out of the ashtray.
Rule of thumb, if it feels bad, it probably is bad, so lay off the gas and take it smooth. |
#13 |
Drives: 2001 E320
Those are some awsome wheels
#14 |
Drives: 05 S500 4m
thats a surefire way to destroy the cv joints on your halfshafts.
Mustang Cobra guys have been fighting this since 99.
__________________
05 S500 4m & 96 993TT |
| Tags |
| 2006, acceleration, amg, applied, bad, brakes, e55, hard, hop, hops, rear, sprinting, takeoff, wheel, wheels |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
