Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W210 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-28-2009, 12:16 PM   #1
Drives: 99 model w210 e55 amg
removing the batteries
hi guys! il be changing the battery that i have on my e55 when i disconnect the battery does it have any affect on the electrical on the car? will things reset? if things are to reset what are those things? and what other things should i look out for? i really have to replace the battery that i have on my car its due for repalcement already.....will it have bad effect do i have to bring it to the dealership? thanks!
To remove this ad, register today or login if you already are registered!
pinoyk20 is offline   Reply With Quote
Old 07-28-2009, 02:09 PM   #2
Drives: E55
It will be fine, it will reset the ECU which is a plus.
MR888 is offline   Reply With Quote
Old 07-28-2009, 03:22 PM   #3
ruBENZ's Avatar
Drives: 2000 E55 AMG/ 1999 996 C2 GT3 Aero Kit
Have your radio code ready. You may also get an ABS/ESP/BAS code when you reconnect; just turn the steering wheel all the way left then right. Also, expect to reset your windows; four seconds in the up position should do the trick. And, yes, your ECU will reset to OEM specs; you will feel the difference. Good luck.
__________________
CautionThe proverbial light at the end of the tunnel may be an oncoming train.
ruBENZ is offline   Reply With Quote
Old 07-28-2009, 04:20 PM   #4
SPONSOR
Drives: AMG
remember to hook up POSITIVE terminals first... THEN negative when you install the new battery (remove in reverse order).
__________________
<<< AMS Performance Website (Click Here) >>>
Please View Website for Important Announcement ...
AMS Performance is offline   Reply With Quote
Old 07-28-2009, 11:03 PM   #5
thanks guys! how can i remove the abs/esp/bas codes? is it by just turning the steering wheel? oh i forgot to say i have an aftermarket radio already. thanks guys!
Old 07-29-2009, 12:24 AM   #6
SPONSOR
Drives: AMG
if you have aftermarket, then no problem at all as far as radio code. Just do 2-3 full turns of the steering wheel (lock to lock) left to right and it will automatically turn off.
__________________
Old 07-29-2009, 08:41 AM   #7
thanks sir!
Old 07-29-2009, 09:03 AM   #8
saintz's Avatar
Drives: 2003 CL600
Make sure the key is out when you disconnect and connect.
Reset the windows, sunroof, and ABS, as described.
http://www.benzworld.org/forums/w210...cronizing.html
__________________
2003 CL600 - Eurocharged
2009 C300 (wife)
2001 E55 AMG - RENNtech Stage 1, Lorinser (sold)
1999 CLK 320 (sold)
2003 WRX, Stage 4 (sold)
saintz is offline   Reply With Quote
Old 07-29-2009, 12:26 PM   #9
thanks sir! why does the key needs to be out? thanks
Old 07-29-2009, 02:19 PM   #10
saintz's Avatar
Drives: 2003 CL600
The system is really picky about the ignition when removing or adding power. I think it has to do with the security module that keeps track of what keys are linked to the car.
__________________
2009 C300 (wife)
1999 CLK 320 (sold)
Old 07-31-2009, 11:53 AM   #11
Quote:
does the engine need to be running when doing the lock to lock thing? and also what the step by step system on doing the lock to lock? another is how to reset the window ? what do i have to do to get the window running on the old memory? thanks
Old 07-31-2009, 12:44 PM   #12
nicobaires's Avatar
Drives: 99 E55 92 400se
they explained here on your post!! scroll up
nicobaires is offline   Reply With Quote
Old 07-31-2009, 12:46 PM   #13
sorry but the explanation iis not clear sir. thanks
Old 07-31-2009, 02:19 PM   #14
saintz's Avatar
Drives: 2003 CL600
Quote:
Yes
Turn the wheel all the way right, then all the way left, and the lights will go out.
The window will "forget" where the top and bottom are. Meaning auto open and auto close won't work. First take the window all the way down (don't use the one-touch auto-down feature, just hold the button half way). Keep holding the button for 5 seconds. Then take it all the way up (again, push the button only half way, don't use the auto up feature). Keep holding the button for 5 seconds once it's fully up. You'll hear a click. Now the window has "remembered" where the top and bottom are and auto-up/down will work. Repeat for all four windows. For the sunroof, hold it in the up/vent position for 5 seconds.
__________________
2009 C300 (wife)
1999 CLK 320 (sold)
Old 07-31-2009, 11:12 PM   #15
thanks! how about the memory on the seats? does it reset?
Old 08-01-2009, 04:18 PM   #16
saintz's Avatar
Drives: 2003 CL600
I think the seats will forget.
__________________
2009 C300 (wife)
1999 CLK 320 (sold)
Old 08-01-2009, 11:32 PM   #17
got my car and evrything is ok! thanks guys!
Tags
2000, amg, battery, code, e55, mercedes, radio, removing, reset, touch, windows
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
