Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W210 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 08-28-2009, 09:28 PM   #1
Drives: 99 model w210 e55 amg
just discoverd the check oil function what else???
hi guys! i have a 99 model e55 so the old type of cluster gauge and yesterday i dicoverd the check oil function and i find it cool heheheh my question is other than the check oil function what other functions does the gauge has? and alos how to check othe functions? thanks
To remove this ad, register today or login if you already are registered!
pinoyk20 is offline   Reply With Quote
Old 08-28-2009, 09:43 PM   #2
Drives: 210 55
No more news my friend!!
Only oil level & time to service in owr clusters
Fabio Daniel
Fabio D is offline   Reply With Quote
Old 08-28-2009, 10:42 PM   #3
oh boy i guess our cars is kinda low tech when compared to the 2000+ models ehehehe by the way about the time to service do he have to follow it? how d we reset it? thanks
Old 08-28-2009, 10:43 PM   #4
and also is the check oil function accurate? thanks
Old 08-29-2009, 01:29 AM   #5
ruBENZ's Avatar
Drives: 2000 E55 AMG/ 1999 996 C2 GT3 Aero Kit
Quote:
OEM oil change intervals vary; every 7,500 and every 10,000 are most common. Time is also a factor. My maximum time is six months. I usually change oil in the 5,000 - 7,500 range. As far as reset goes, that function is found within my instrument cluster.
I have found the check oil function accurate to four ounces. Beyond four ounces produces an "add oil" display.
__________________
CautionThe proverbial light at the end of the tunnel may be an oncoming train.
ruBENZ is offline   Reply With Quote
Old 08-29-2009, 02:33 AM   #6
nice! THANKS!!!!
Old 08-29-2009, 06:39 AM   #7
Drives: W210 E55 AMG
You might as well tell the rest of those who don't know how to do the check oil function procedure.
Silver Logic is offline   Reply With Quote
Old 09-01-2009, 09:05 AM   #8
nicobaires's Avatar
Drives: 99 E55 92 400se
So how is this done??
nicobaires is offline   Reply With Quote
Old 09-01-2009, 07:44 PM   #9
ruBENZ's Avatar
Quote:
For a 2000 E55, and the vehicle in a level position, one begins with the ignition key in the second position. Do not start the vehicle. With your instrument cluster displaying the odometer, press the up arrow twice. This will display the oil level screen, and begin the oil level measuring function. Within ten seconds the display will read: Oil level OK, Add oil level low, or Reduce oil level
__________________
Old 09-01-2009, 08:27 PM   #10
Drives: 210 55
To your 99" you need to sit the key in position 2 (not start the engine) & wait 10 - 15 seconds. when the display say "CHECK OIL LEVEL?" you need to push 2 times the "0" button in the instrumment cluster & then say OIL OK, FILL, REMOVE or so.. (you need to have the car in 100% horizontal position)
Fabio Daniel
Old 09-02-2009, 08:59 AM   #11
nicobaires's Avatar
Thanks guys, I will try it later today
Old 09-02-2009, 10:13 PM   #12
Bellefonte's Avatar
Drives: 2002 E55
There is an a/c diagnose tool in the climate control that I thought was pretty cool...
http://www.eclassbenz.com/node/27
Bellefonte is offline   Reply With Quote
Tags
2006, amg, benz, check, checking, climate, cluster, control, e55, instrument, key, level, mercedes, oil, reset, w210
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
