Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W210 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-17-2012, 01:39 PM   #1
PLATINUM SPONSOR
Cory @ Kleemann's Avatar
KLEEMANN W210 Headers IN STOCK!!
I'm very pleased to announce that the KLEEMANN W210 headers for the M113 engine are now in stock and ready to ship!! We will be offering these headers, inclusive of all necessary gaskets, bolts, etc. at a (re)introductory price of $995.00 plus shipping. Please contact me directly at cory@kleemannusa.com (or 719.473.6441) if you have any questions or if you'd like to place an order.
To remove this ad, register today or login if you already are registered!
Cory @ Kleemann is offline   Reply With Quote
Old 01-19-2012, 10:26 PM   #2
snooozie's Avatar
Drives: 86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
Quote:
Can you let us know, for those of us who are interested, are these headers a direct bolt on or do we need to do modifications to the downpipe or welding to get them on. I live in CT hence how much is shipping to 06479. Thanks.
Also, can you post some pictures of the headers for us to see.
__________________
Diesel turn Gasoline
Current MB:
02 E55
Mod: x-pipe/resonator delete/AMS headers/AMS crankshaft pulley/Renntech CF Airbox with AFE Pro Dry S Filter/2nd cat delete/H&R Springs/Ghost's Rear Camber Kit/ECU tuned
Previous MBs:
81 300D Wagon
80 240D 4sp (10 gallon extra tank in the trunk)
86 190D w/ Eibach Springs
87 300TD w/ Eibach Springs
99 E300D (RIP)
"It's only a money pit when your broke"
snooozie is offline   Reply With Quote
Old 01-20-2012, 10:47 AM   #3
PLATINUM SPONSOR
Picture attached of the full W210 header kit. Like all KLEEMANN headers for the M113 engine, cutting and welding is required, and the headers omit the primary catalyst. As always, we'll include ECU coding which will eliminate the MIL for catalyst and will also force-set readiness monitors, however, this only works on cars with ME2.8- cars using ME2.0 (usually 1999-2000 and some early 2001 production), the secondary O2 sensors must be relocated behind the secondary catalyst, or the readiness monitors must be disabled via ECU programming (which means you'll fail OBDII tests).
Old 01-20-2012, 11:39 AM   #4
snooozie's Avatar
I have a 2002 and when I install the x-pipe, I didnot see any O2 sensors on the 2nd cats. Is it better to delete the two 2nd cats when installing the headers. I don't have any problem with OBDII.
__________________
Current MB:
02 E55
Previous MBs:
81 300D Wagon
99 E300D (RIP)
Old 01-20-2012, 01:26 PM   #5
PLATINUM SPONSOR
I'm not sure I even suggested there were O2 sensors in, around or after the secondary cats. What I'm saying is, IF your car has ME2.0 and you're installing our headers, the only way to eliminate getting a MIL for the removal of the primary cat (it's not possible to use the factory cat when installing our headers) is to either re-locate the secondary O2 sensors behind the factory secondary catalyst (they originally reside after the primary cats), or have the readiness monitors disabled via an ECU tune.
Old 01-20-2012, 01:35 PM   #6
CharlyE500's Avatar
Drives: E55 2006 / E55 2000 / White Odyssey
This looks bigger and longer than W211 header.
__________________
Good judgment comes from experience, experience comes from bad judgment.
Kleemann ECU tune + Header + CM30 pump + K&N filter + E63 front conversion + SL55 Gun metal wheels
CharlyE500 is offline   Reply With Quote
Old 01-20-2012, 01:59 PM   #7
PLATINUM SPONSOR
Quote:
The headers are not larger in terms of pipe diameter, and the overall design is different- you'll notice the W210 headers use a 4-2-1 design where the W211 headers use a 4-into-1 merge collector. The W211 headers use a larger pipe at the outlet of the collector as well. The W210 down pipes are longer to be sure, but the pipe diameter is actually smaller than a W211. Also keep in mind these were designed long before the W211 came out....
Old 01-20-2012, 03:19 PM   #8
Drives: AMG 2002 E55, 1997 E320
Will California cars with the newer ECU pass smog?
__________________
________________________
2002 AMG E55 40K on the clock
1997 E320 210K on the clock
tsquare is offline   Reply With Quote
Old 01-20-2012, 03:25 PM   #9
Drives: ML55 Daily Beater?
good looking stuff corey!
__________________
5000lbs of Get The Eff Outta My Way
JAYCL600 is offline   Reply With Quote
Old 01-20-2012, 03:39 PM   #10
PLATINUM SPONSOR
Quote:
I can almost definitively say no, and it's not got much to do with the ECU. Removing the primary catalysts means your asking the secondaries to do more which means you'll likely still have high CO and NoX readings, you'll very likely fail the visual inspection (it's my understanding that some stations do it, while others don't), and if they see headers on the car, they'll want a CARB EO number, which our headers do not have. I say almost definitively because I have heard of people passing without any issue, so it's somewhat dependent on the specific inspection station you go to.
Old 01-22-2012, 10:12 AM   #11
Drives: W210 E55
As Cory mentioned, some stations know what to look for, others don't. I do not know if these cars will pass smog with only the primaries (I suspect they will and I will find out in a few months).
There is no reason one can not cleverly relocate the stock primary cats before the resonator or x-pipe. They are metallic and flow well. The secondaries and manifolds are the primary restrictions in the W210 E55's. I imagine that if I were to do this, I might need to extend the O2 sensor wires back a little further.
This is a very good deal. There is definite engineering in the Kleeman headers as evidenced by the right side header alternating cylinders for initial collection.
Schweinhund is offline   Reply With Quote
Old 01-22-2012, 10:18 AM   #12
Drives: W210 E55
Cory,
I know its an ancient question, but do you have some stock vs this setup dyno runs on a W210 E55?
Thanks.
Old 02-21-2012, 01:41 PM   #13
Drives: W210 E55
Cory,
If I wanted to go with your headers setup but also install four new cats (cut the lower pipe sections), would ECU reprogramming be required?
My idea is to go with four metallic cats (two on each side) as in the stock layout.
Old 02-21-2012, 03:10 PM   #14
CharlyE500's Avatar
Quote:
Originally Posted by Schweinhund View Post
Cory,
I think you better email him since he is not in the forum all the time.
__________________
Old 02-21-2012, 05:24 PM   #15
Drives: W210 E55
Thanks, did.
Old 06-01-2012, 11:03 PM   #16
Drives: w210 e430
headers
if i have straight pipes with no cats, would i have to worry about ecu remapping or can i just slap them on with no worries? or would i be running headers without noticing any difference?
benzo956 is offline   Reply With Quote
Old 06-02-2012, 10:11 AM   #17
Drives: W210 E55
If you are already running no cats, these headers should make no difference "CEL"-wise. If you do this, do a dyno run before and after!
Old 06-02-2012, 10:52 AM   #18
snooozie's Avatar
Curious
Quote:
Just curious..if you delete your primary cats, didn't you get a CEL on your dash? Unless you have your ecu tune you will get a CEL. How did you go around that? I'm curious to know. Also, with straight downpipes, what ever happen to the O2 sensors...you just delete them?
__________________
Current MB:
02 E55
Previous MBs:
81 300D Wagon
99 E300D (RIP)
Old 06-03-2012, 12:19 PM   #19
Drives: w210 e430
headers
actually, i bought the car as is, sence it was loud i checked what it had and thats when i found out it had straight pipes, as far as the o2 sensors they seem to be in the same spot, what i do have is a check engine light always on, ive gotten it checked and all they tell me is since i dont have cats itll stay on but doesnt affect it in anyway. so to sum it up i guess i can put the headers with no worries
Old 06-03-2012, 01:03 PM   #20
snooozie's Avatar
If you buy the kleemann headers, you can call Cory, and mail your ECU to him. He will tune your ecu to by pass the sensors and your CEL light will not come on anymore Its something they have to do as the kleemann headers are long tubes hence your primary cats have to be deleted.
__________________
Current MB:
02 E55
Previous MBs:
81 300D Wagon
99 E300D (RIP)
Old 06-03-2012, 01:17 PM   #21
Drives: w210 e430
headers
im calculating around $1800 for headers plus ecu? quite some cash, itll have to wait for income :/ thats if they still have it available
Old 06-03-2012, 01:28 PM   #22
snooozie's Avatar
If you buy the headers from Kleemann, Cory will delete the CEL light via the ecu for free. He told me that on the phone. You just have to sent in your ecu....probably take a few days round trip.
__________________
Current MB:
02 E55
Previous MBs:
81 300D Wagon
99 E300D (RIP)
Old 06-03-2012, 01:43 PM   #23
Drives: w210 e430
headers
sweet!!! then ima save up, 100 bucks to set aside on every pay check should do the job thanks for the info
Old 11-20-2012, 08:24 PM   #24
midnightsaint's Avatar
Drives: 1995 E320
What's hp gain from these?
__________________
midnightsaint is offline   Reply With Quote
Tags
02, 300d, 320, amg, cory, cut, delete, e320, e55, headers, kleemann, resinator, small, springs, stockmbworld, w210
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
