Sign in using an external account
| W210 AMG Discuss the W210 AMG's such as the E50, E55, and E60 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 E55 AMG Obsidian Black with Charcoal
Drive shaft bearing noise?
#2 | |
Drives: 1 out of 1125 C43's imported to U.S.A
Quote:
)If the flex discs have cracks in them they need to be replaced, jack your car up or put it on a lift and use a flash light to inspect them.
__________________
#3 |
Drives: 2000 w210 E55
I think that my flex disc might be going. I just replaced my motor mt. Still hearing a slight knocking.
#4 |
Drives: 2001 E55, 2002 Dodge Durango
Would the center bearing make an intermittent vibration when it's going bad? I've got one from about 43mph-51mph and I'm thinking that may be the cause.
__________________
2001 E55 - Goodridge SS brake lines, Plasti-dipped grill, flat badge, Bilstein Sport shocks, H&R springs w/ 1 coil removed from the fronts and 1/4 from the rears 2002 Dodge Durango 1977 Ford F250 4x4 Highboy - 351M/4spd manual, 33" tires, it's a beast - Sold 12-22-12 :( |
#5 |
When my center support bearing went out I could feel a vibration and hear a slight knocking at low speed, basically @ take off. After I passed 15-20 MPH the vibration and knocking disappeared.
__________________
#6 |
Is that a simple fix, center support bearing?
#7 |
Drives: W210 E55
I am paying attention. I have a slight vibration right around 15 MPH speeding up or slowing down) then it goes away. I thought it might be my tires but they are only a year old.
I suspect it might NOT be the bearing since I still get the vibration even if I slow down in neutral (which should unload the driveshaft) which would eliminate the vibration. Nothing I try impacts the vibration. It's always there as I pass 15 MPH. |
#8 |
Drives: 01e55blk/blk
I was going home lastnight and while driving through the city i hadnt heard nothing as I got on the freeway and got it over 60 just cruising speed I would blip the throttle alil and as I would let off I could feel a GRRR so i did it again and again made same noise , though it might be exhaust at first but now i suspect its some sort of grinding or vibration sh*t after seeing this thread got me worried lol
__________________
#9 |
My noise ended up being the driver's side rear wheel bearing. I just replaced it myself. A fairly easy job.
#10 |
Drives: 1999 Mercedes Benz E55 AMG
#11 |
Drives: 86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
yeah....when you get a chance, please write a DIY to help us out....thanks!!
__________________
Diesel turn Gasoline Current MB: 02 E55 Mod: x-pipe/resonator delete/AMS headers/AMS crankshaft pulley/Renntech CF Airbox with AFE Pro Dry S Filter/2nd cat delete/H&R Springs/Ghost's Rear Camber Kit/ECU tuned Previous MBs: 81 300D Wagon 80 240D 4sp (10 gallon extra tank in the trunk) 86 190D w/ Eibach Springs 87 300TD w/ Eibach Springs 99 E300D (RIP) "It's only a money pit when your broke" |
#12 |
I can't add anything to the previous thread about the procedure. It's all straight forward.
Here are some pictures of the bearing that failed. |
#13 |
Drives: W210 E55
Wow. That thing was GONE.
#14 |
Drives: w211 e220 cdi
I have same noise since a year
I have w211 E220 Cdi automatic gear (now i have a noise with vibration in the first gear (OR before first gear)and you can also say it is from 0km-to 10km then it goes
yesterday I took it to your neighbors ( he is a mechanic but young about 19 years old )i am not sure he is a specialist i this kind of cars but he check it and told me that the drive shaft has a problem in the middle (like a space) he moves it and hear a knocking in the middle like a space in he told me that it is the problem but I was worried if he isn't right because the sound and the vibration is very hard and I think it is from the gear itself or a clutch in the gear and when he check and move the drive shaft with his hand up and down the gear was in neutral IS HE RIGHT A SPACE IN CENTER OF THE DRIVE SHAFT MAKE THIS NOISE???AND WHY IT IS JUST IN THE FIRST GEAR NOT IN ALL |
| Tags |
| amg, bearing, center, disc, drive, e55, flex, knock, mercedes, noise, noises, shaft, symptoms, w210, w211 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
